m sprank Posted March 9, 2013 Share Posted March 9, 2013 I get asked about LWFW's so often it made sense to post some info in one place. Hope this helps. Any and all light weight flywheels will "chatter". It is the nature of a LWFW, along with the change in inertia. Even the OEM SMFW can have some chatter/judder. All Competetion Clutch kits for the LGT currently use and include a LWFW. They will chatter. 06+ WRX (which shares compatability with the 05-09 LGT) uses the same kits. 02-05 WRX use a different kit (which can use the OEM FW). So, for 05-09 LGT owners all current Comp Clutch offerings include a LWFW and must be used with the provided LWFW (the pressure plate will not bolt up to an OEM FW). Enthusiasts considering a lightweight flywheel are often warned of "lightweight flywheel noise", or "chatter" more correctly called "gear rattle" or "gear lash noise". In making modifications to any car, there may at times be certain compromises in other areas of the car's behavior. Some may be completely acceptable, others may not. In a luxury-minded enthusiasts car like a LGT, owners are concerned about new or excessive sounds or rattles. The original dual-mass flywheel does one thing very well - exhibits inertia, the resistance to changing it's state of motion. It is more difficult to change the speed of the dual-mass flywheel, whether accelerating it or slowing it down... that means besides inhibiting engine acceleration to some degree, it also inhibits the deceleration that occurs between every power pulse. The power pulse transition is smoother, therefore no rattle. A single-mass flywheel is the same sort of design as a solid aluminum lightweight flywheel: a rigid disk of metal, either aluminum or steel. In the OE applications, these flywheels are equipped with a sprung-hub clutch. The sprung-hub clutch "splits the difference" between the these situations. The friction material (the disk itself) is not "hard coupled" to the hub, but has a springy nature to the assembly. It has a suspension, the springs you see around the hub. What this accomplishes is letting the power pulse couple the transmission's internal parts softly, and then de-couple softly. ("Softly" being a relative term here, it is just a few millimeters of travel, nothing that can be felt.) The net result is the difference between banging two pieces together and gently placing them together. The lightened flywheel has less mass to damp the power pulse variations. The tolerances of the gears,splines and general internals are low. They are "loose". The dual mass units and heavier singles, dampen the engine pulses/harmonics through the shafts. The lighter units, dont do such a good job of it. Subaru switched over to the SMFW for LGT's in 07. So using a 06+ WRX set up is the same as a 07-09 LGT set up. 05-06 were the years that got the DMFW. Most likely to save coin, Subaru decided the change was acceptable. Some users have complained of light "chatter" or "judder" when using an aftermarket clutch and the OEM SMFW. Seems to be more temp related and factored by the disc choice and pressure plate strength. Misfires, CEL's etc are caused by a FW that is too light. Most LGT LWFW's are in the 14lb-15lb range and are not light enough to cause this. Going to 12lbs will deff throw a CEL. Comp Clutch LWFW's are 14.5 lbs. Link to comment Share on other sites More sharing options...
m sprank Posted January 1, 2014 Author Share Posted January 1, 2014 http://legacygt.com/forums/attachment.php?attachmentid=171328&d=1388592819 Link to comment Share on other sites More sharing options...
m sprank Posted March 26, 2016 Author Share Posted March 26, 2016 Have a Happy Easter!!! Link to comment Share on other sites More sharing options...
m sprank Posted November 11, 2016 Author Share Posted November 11, 2016 http://www.infamousperformance.net/storage/happy-veterans-day-pictures.jpg The soldier above all others prays for peace, for it is the soldier who must suffer and bear the deepest wounds and scars of war. Douglas MacArthur Link to comment Share on other sites More sharing options...
