zrzxpete Posted July 14, 2004 Posted July 14, 2004 Hello, I have a 1999 Leagcy Outback Limited 30th Ann wagon that I am trying to add a factory CD changer to my OEM deck. The deck is a double din chassis with single CD/Tape/FM/AM/weather bands. It was made by Panasonic. I found a factory changer on eBay but it did not come with the connecting cable. I asked the seller what happened to the orginal cable. He said that he did not remove the cable when his lease was up. I contacted AuburnSubaru.com to get a replacement They exhausted their knowledge trying to find one. According to Auburn the only way to get another cable is to order a new changer. Turns out the Limited 30th Ann model had a unique in-dash unit and changer. After stricking out with Subaru, I went to Partsolver.com. I found three cables. I contacted them to figure out what cable it could be. According to Partsolver all 3 cables are no longer avaiable. They never told me if any of the 3 cables were the correct one. I looked to http://www.ultimatesubaru.net for help. Found out that this particular CD chamger was brought to the US for my 30th ann Sub only. I know that the Changer end of the cable has a 12 pin rectangular connector. The head unit has 16 pins. No RCA or Din. The changer has an additional spade conn. I am guessing this is a ground. See pic. The part model # of the changer is H6240AS200. If anyone has a changer like mine please contact me. I would be greatful if you could look on it for a part number or help out with any additional info. Thanks Pete
zrzxpete Posted July 19, 2004 Author Posted July 19, 2004 Someone has to know something anout this changer. It only takes a minute to peek under your passenger seat. pete
