curtishaword Posted February 20, 2013 Share Posted February 20, 2013 New Member just looking for advice in building an automatic gt daily driver. I have questions such as how far can I go before needing a tune? Can an STI intake be swapped or just get new injectors? Never built a car before, but have mechanical knowledge. Any advice is great, thanks. Link to comment Share on other sites More sharing options...
a93x Posted February 20, 2013 Share Posted February 20, 2013 Trans is good till about 300whp. Then you will want the HEXMODS valve body upgrade ($500) No need for an intake for quite some time. You also don't need to touch your injectors for some time. Go get a catless Uppipe/ down pipe/ grim speed boost control solenoid (EBCS) / tune and you'll be happy. torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 20, 2013 Share Posted February 20, 2013 You need a tune first.. there are flaws in the factory map. Get a cobb Ver2. or if you are good with cars and computers you can look up using a VAG Comm Cable/Tactrix and rom-raider.. PM Cryo for E-tune info or check on tuning forum.. Get used to searching, this website probably has all your questions answered already. Basically, get a panel filter or short ram intake, CBE, Up-pipe and your stg1 and will be happy.. for a little bit.. Link to comment Share on other sites More sharing options...
curtishaword Posted February 20, 2013 Author Share Posted February 20, 2013 Thanks for the tips. One more question, keep stock exhaust manifold? But does changing that lead to needing a tune? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted February 20, 2013 Share Posted February 20, 2013 Don't plan on brake launching a lot. You will hurt the trans. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 20, 2013 Share Posted February 20, 2013 Plan the build and the budget, do it all once, less tuning worries.. But some will say yes and some will say no.. Link to comment Share on other sites More sharing options...
