05 LGT AT 146K, engine braking does not work
Hi guys, i have 05 legacy gt AT with 146K miles, but have new shortblock with 2000 miles on it. While i'm going down step hill, i usually try to downshift to 4th and let engine slow down so i don't have to use brakes(i live in High Rockies). For some reason when i downshift in manual mode my speed will not decrease, instead rpms will climb up and i have to upshift and use brakes.
First thought is to do a compression test to make sure that it's ok (not that there should be any big problems there with an almost new block). And double-check the cam timing too. But as noted above - that the car rev-matches when downshifting, so the braking may not be immediate.
What about if you downshift to 3rd?
But a turbo engine has a lower compression ratio, so engine braking isn't as effective as with a naturally aspirated engine.
Don't worry about engine wear when engine braking. It's a lot less wear on the engine doing that than going uphill.
The coasting clutch - or lock-up is bypassing the torque converter, and when driving you should be able to notice if it engages or not. Best is a flat straight piece of road.
Accelerate slowly up to 45 to 55mph, and pay attention to every gear shift. If you have a final shift where the change is just about 100rpm it should work as intended.
