Flashing Cruise Light
So this morning I started off in my car and I notice that the cruise light was flashing.So I thought that if I played around with the cruise control buttons that it would stop,but it didn't. Then for some reason I started to think as if it was a computer and reboot it. So I pulled over a turn the car off and restarted problem solved. My question is what cause the cruise light to flash.
What brand front wheel bearing did you use ?
I'll bet it wasn't a OEM hub assembly!!!
You need to use a OEM hub assembly on these cars. Trust me on that one. Been there done that.
I even put the old OEM hub back in to verify the Moog wasn't working correctly.
A lot of us have learned the same lesson.
Rears, Moogs work fine, but the fronts have to be OEM.
BTW, OEM is cheaper.
Engine Build - Click Here
