Chris GTO TT Posted December 27, 2012 Share Posted December 27, 2012 When I turn the car to the on position without starting the car I'm getting an electronic buzzing noise that is new coming from what sounds like under the intake manifold. Pretty sure that is the location it is coming from. I'm still under the power train warranty so I'm thinking of taking it to Subaru on Saturday. [ame=http://www.youtube.com/watch?v=GAo2iJhrtx8]Electronic buzzing - YouTube[/ame] 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
m sprank Posted December 27, 2012 Share Posted December 27, 2012 Throttle body? Most buzz. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 27, 2012 Author Share Posted December 27, 2012 So it normal and nothing i should worry about? 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
m sprank Posted December 27, 2012 Share Posted December 27, 2012 I dont have speakers, lol. Cant "hear" the vid. But buzzing throttle bodies is normal. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 27, 2012 Author Share Posted December 27, 2012 Ok, I was just concerned because this was a 'new' noise. One I had not noticed in the other times I've had the hood opened with the ignition in the on position. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
ripemeat Posted December 27, 2012 Share Posted December 27, 2012 normal, the drive by wire throttle body makes an electric-buzz noise when the key is on ON position or the engine is running. the throttle body flapper motor is essentially one big servo, and servos are designed to make split second movements and response times. Link to comment Share on other sites More sharing options...
Strizzy Posted December 27, 2012 Share Posted December 27, 2012 Yup. Normal. It'll make even more noises if you press the throttle. My bad luck build Link to comment Share on other sites More sharing options...
fishbone Posted December 27, 2012 Share Posted December 27, 2012 Hey guy, not sure if anyone has told you this so I thought I would post up in here and say. Yes that buzz is normal and is coming from the throttle body. I can hear it too. Link to comment Share on other sites More sharing options...
RoscoeOutback Posted May 31, 2018 Share Posted May 31, 2018 2008 OBXT w/130K. My OB did not make this noise until last night. I did an out id car HG repair and when I got everything back together the car, starts rough, won't idle and now makes this buzzng sound described here and elsewhere in the forum. To me, it is clear that thebuzzibg is related to my issue and that it is not normal. When I figure iut whats wrong with my rebuild and i fix it, the buzzing will stop and thecar will return to nirmal. I will post outcone. Link to comment Share on other sites More sharing options...
m sprank Posted May 31, 2018 Share Posted May 31, 2018 You have an entirely different issue caused most likely by something amiss with the engine re-install. Link to comment Share on other sites More sharing options...
