BrenTuning: 2005 Legacy GT Tomioka 20G 5EAT
BrenTuning
Event: Dyno tune
Car: 2005 Legacy GT
Tuner: BG @ BrenTuning
Temperature: Mid 40s
Dyno Info: Dyno Dynamics Digital, Shootout
Transmission: 5EAT
Gear: 3RD
Peak HP: 335whp
Peak Torque: 375wtq
Baseline hp/tq for stock on same dyno: Unknown
Target Boost: 19psi peak to 18psi redline
Fuel: 93 E10
Engine/Power Modifications:
Stock motor
AEM CAI
TD06 20G Turbo LGT fitment
DW740 Injector
Walbro 255
FMS TMIC
GT Spec header
Limitations: Transmission and motor. Car was very solid here at this level. It is very difficult to not sit on the limiter in 1st gear with this type of power in the a 5EAT that has some mileage on it. They get a bit sloppy in between gears and hang. You must modify the drive by wire towards redline to get these cars to shift. A valvebody upgrade is recommended and also a transmission cooler. On the DD dyno the converter will unlock/lock mid pull so it's a bit difficult to tune on the dyno. They usually will slip a bit around 5000 each pull.
I am a big fan of this turbo, it moves a lot of G/S for it's size. It is decently expensive for an off branded turbo. Time will tell but this is the 3rd one I've done. The 5spd LGT made 350whp/400wtq.
http://i769.photobucket.com/albums/xx332/brentuning/05LGT20GWAGONAUTO.jpg
