Silinc3r Posted November 11, 2012 Share Posted November 11, 2012 (edited) Picked this beauty up over the weekend in Atlanta. Was very lucky to find this in Atlanta for the price and low miles. Its not the Limited but it is everything else I wanted, color, 5spd, GT, black interior. Also came with a fair amount of goodies . 2005 Unlimited GT 5spd Satin White Pearl 82033 miles upon purchase http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0675.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0673.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0672.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0671.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0669.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0668.jpg I am guessing this was done to keep the car from throwing a O2 code http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0664.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0663.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0661.jpg If anybody recognizes this car please let me know because I would like to know what all has been done. Car was originally from Virginia. Mods: As of 4/10/17 Engine: Grimmspeed intake Perrin turbo inlet Samco BOV hose STi Genome strut bar Dressupbolts kit, titanium true burned Bulletproofed black TMIC Zero Sports cool action II intercooler splitter in BLUE!! Zero Sports radiator shroud Zero Sports alternator shroud Zero Sports 1.3 BAR rad cap Zero Sports 1.1 BAR expansion tank cap Zero Sports V-Effector Voltage Stabilizer & V-Earthing Ground GFB response BOV AVO throttle body hose Moroso dual catch cans Glowshift oil sandwich adapter plate KillerB windage tray and oil pickup tube Exhaust: Megan racing dual tip muffler Tomei Expreme (DEI tit wrapped) Tsuedo cast bellmouth down pipe (DEI wrapped) Power: Tuned to 19 PSI open source -DrunkmannTuning "Stage 2" VF52 DW65C GS EBCS Hallman manual boost controller (hybrid setup) Suspension: BC BR coilovers Perrin pitch stop Group-N motor mounts Wheels: Enkei TS10 18x8 Gold!!!! H&R 5mm spacers H&R extended studs Bridgestone Potenza s-04 Pole Postion 225/45/18 JDM STi lug nuts Stopping: Brembo calipers up front Stoptech rotors and Stoptech pads upfront Stoptech slotted rotors and pads in rear Gforce lines Grimmspeed master cylinder brace Interior: Tommy Kaira, Heavy Baby shift knob 2006 Spec B interior Zero Sports 350mm steering wheel 2006 spec shifter surround with number plate 419/500 Crown Royal shifter boot JCSpod dual A pillar AEM wideband Prosport boost gauge FastWRX pre/post intercooler temp guage Defi triple gauge pack, oil temp, oil pressure, water temp Kenwood DNX571HD JDM dual HVAC setup JDM hazard Factory STi short shift STi push start button Factory underseat sub X2!! Exterior: Tint-20% JDM STi Genome grill JDM aero spats JDM strakes JDM headlight garnish JDM rear tail light garnish L7 badge rebadged Spec B BaysonR LGT front lip R-Rev CF rear roof spoiler R-Rev CF scoop bulge R-Rev switchbacks R-Rev reverse lights R-Rev license plate lights Dynoed at Emerald Coast Motorsports 255hp/277tq http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG1758.jpg Edited September 27, 2017 by Silinc3r current mods Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 11, 2012 Share Posted November 11, 2012 It has an Aftermarket uppipe. Or possibly an STi uppipe. That connector you found is for the OEM uppipe. Price. Link to comment Share on other sites More sharing options...
Waxiboy Posted November 11, 2012 Share Posted November 11, 2012 I bet you also have a catless up pipe, hence the resistor. Link to comment Share on other sites More sharing options...
wurkenman Posted November 11, 2012 Share Posted November 11, 2012 Welcome. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Hepy117 Posted November 12, 2012 Share Posted November 12, 2012 Looks like it has an aftermarket DP also. Might want to get a vagcom cable and pull the map to make sure it's tuned properly. Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 12, 2012 Share Posted November 12, 2012 Looks like it has an aftermarket DP also. Might want to get a vagcom cable and pull the map to make sure it's tuned properly. And you can see this how? Link to comment Share on other sites More sharing options...
Silinc3r Posted November 12, 2012 Author Share Posted November 12, 2012 And you can see this how? you can see it in the picture with the plug that has the resistor in it yea I am pretty sure it needs a tune, its a little rough when I step on it but other than that no problems and I got 26 MPG from Atlanta to Mobile and that was with doing some power trials Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 12, 2012 Share Posted November 12, 2012 Why the resistor? My walkthru' http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-2k-5w-resistor-up-pipe-131488p2.html Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 12, 2012 Share Posted November 12, 2012 (edited) Edited November 12, 2012 by Haight 05LGT Link to comment Share on other sites More sharing options...
.Catalyst. Posted November 12, 2012 Share Posted November 12, 2012 Pretty sure that's an aftermarket DP. In the EGT sensor harness picture with the resistor - you can see a WBO2 bung welded in and lack of upper cat that would be present in an OEM DP. Also, you will want an engine cover if you plan on running that OEM TMIC. Also should "bulletproof" it since you are likely running a Stage 2 tune, (BarManBean is working on a new batch). If you need an OEM engine cover I happen to have one that's perfect I'm willing to part with The engine cover helps seal the splitter to the TMIC. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 12, 2012 Share Posted November 12, 2012 Pretty sure that's an aftermarket DP. In the EGT sensor harness picture with the resistor - you can see a WBO2 bung welded in and lack of upper cat that would be present in an OEM DP. Also, you will want an engine cover if you plan on running that OEM TMIC. Also should "bulletproof" it since you are likely running a Stage 2 tune, (BarManBean is working on a new batch). If you need an OEM engine cover I happen to have one that's perfect I'm willing to part with The engine cover helps seal the splitter to the TMIC. Haha you are so right...I retract my previous statements. I did not look past the sensor in the picture. Good call. Definitely aftermarket. Link to comment Share on other sites More sharing options...
Silinc3r Posted November 12, 2012 Author Share Posted November 12, 2012 Why the resistor? My walkthru' http://legacygt.com/forums/showthread.php/unofficial-05-06-lgt-2-2k-5w-resistor-up-pipe-131488p2.html Are you asking me or just showing me that I was correct in my thought, except its EGT and not O2:redface:. Thanks none the less And Catalyst I might have to take you up on that So does anybody recognize this vehicle? Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
cryo Posted November 12, 2012 Share Posted November 12, 2012 Congrats on the purchase. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
Haight 05LGT Posted November 12, 2012 Share Posted November 12, 2012 Are you asking me or just showing me that I was correct in my thought, except its EGT and not O2:redface:. Thanks none the less And Catalyst I might have to take you up on that So does anybody recognize this vehicle? Knowing Max, it was a rhetorical question I'm sure. Link to comment Share on other sites More sharing options...
Cone_Killer Posted November 12, 2012 Share Posted November 12, 2012 Bilstein's look fairly new. That is a nice pre-purchase upgrade. Link to comment Share on other sites More sharing options...
Hepy117 Posted November 12, 2012 Share Posted November 12, 2012 Does it only have the bilstein's on the rear? Link to comment Share on other sites More sharing options...
Silinc3r Posted November 13, 2012 Author Share Posted November 13, 2012 Yes they are only on the rear. Not sure which car or year they came off of though. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
Screamin Posted November 13, 2012 Share Posted November 13, 2012 Nice purchase. My .02.... Tune, which has already been stated many times so far. Get your uppipe and downpipe wrapped up. You should also, IMO, get a turbo blanket or at the least a turbo heat shield. You have LOTS of heat coming off all 3 parts and need to get your under hood temps under control. Your intercooler I'm sure is getting heat soaked like a mofo. Link to comment Share on other sites More sharing options...
Silinc3r Posted November 13, 2012 Author Share Posted November 13, 2012 I guess I should have wrote what my plans where to do so no one would have to keep repeating one another. However I would think the intercooler is good traveling in triple digit speeds, JK. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
.blackgt. Posted November 13, 2012 Share Posted November 13, 2012 Question for you all. Do you see the rubber coolant hose that makes a hump over the intake tube? It is turning white. This is due to coolant. Do these hoses crack or seep at all? Mine is doing the same thing and there are no visible leaks at the union where it meets the hard line. Just curious if people see this problem alot on that specific hose. Thanks. Link to comment Share on other sites More sharing options...
.blackgt. Posted November 13, 2012 Share Posted November 13, 2012 http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0661.jpg Here's a clear picture of it. Link to comment Share on other sites More sharing options...
Silinc3r Posted November 13, 2012 Author Share Posted November 13, 2012 Huh nice catch, didn't reall pay much attention when at the dealership. Noticed it but didn't think about it. However this is for the expansion tank line only and should only see heat if there is an over heat or fire. Also drove the car from Atlanta to Mobile and didn't have any problems so I'll keep an eye on it incase there is a pin hole in the hose. Thanks for pointing it out. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
Silinc3r Posted November 30, 2012 Author Share Posted November 30, 2012 So little update, have been saearching around on things I need to do after purcahasing the vehicle; oil/filter change, tranny and rear diff fluid change and came across the warranty on the wheel bearings. The innitial warranty was through 08/07/09 and was extended annother 40,000 and 36 months to 08/31/2012. So I went to Subaru dealership and went to ask about it and he showed me that I just missed the expiration but to call SOA and see what they can do. The part is only 135 dollars so I might just end up doing it myself as it will just be easier and cheaper for me to go that route but I'll still check. Also upon pulling up my VIN# he was able to show what all had been done to the vehicle adn it showed the right rear had all ready been replaced. ALSO I found the option that where equiped and found a nice little goodie- T5A or also known as a Short Throw Shifter. So for anyone interested in buying any SUBARU grab the VIN# and go to a dealership and have them pull up the information. I didn't think/know about it when I was buying the car but I know now. CARFAX did not show all of this information. Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
Silinc3r Posted March 29, 2013 Author Share Posted March 29, 2013 So a small update. Finally got some stock splash guards which I am a fan of. Not really into the RA mud flaps. http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0901.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0888.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0889.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0890.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0891.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0892.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0895.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0896.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0897.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0898.jpg http://i733.photobucket.com/albums/ww331/TonyHamre/05%20GT/IMAG0900.jpg And trying to decide between the STi Enkei golds or Prodrive GT1s Silinc3r's 05 SWP GT/Spec B Link to comment Share on other sites More sharing options...
lee07 Posted March 29, 2013 Share Posted March 29, 2013 I know you said you like the splash guards, but better take them off now as it will start to rust under and behind it in a few years, unless you don't see snow and salt but then you still get rain. All of my 3 previous cars had rust with those slash guards Link to comment Share on other sites More sharing options...
