BoFoSho Posted November 22, 2016 Share Posted November 22, 2016 Whats the recommendation for greasing up the retainers and the caliper pins? I use 3M silicone paste on the caliper slide pins and any old moly grease on the pad retainer clips. https://www.amazon.com/3M-08946-Clear-Silicone-Paste/dp/B005RNEH5O Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 22, 2016 Share Posted November 22, 2016 Are these just for the rears? Amazon only lists the rear as compatible. fronts https://smile.amazon.com/Raybestos-H15215-Professional-Grade-Caliper/dp/B0049L6OSI/ref=pd_sbs_263_2?_encoding=UTF8&pd_rd_i=B0049L6OSI&pd_rd_r=2DJ6DHZ4S1688PF3AXNE&pd_rd_w=4zmJg&pd_rd_wg=t7nrX&psc=1&refRID=2DJ6DHZ4S1688PF3AXNE rubbers https://smile.amazon.com/Carlson-Quality-Brake-Parts-16055/dp/B000BZWWZU/ref=pd_bxgy_263_img_2?_encoding=UTF8&pd_rd_i=B000BZWWZU&pd_rd_r=YE1STZF4GQ0M3A077QQW&pd_rd_w=uQC8I&pd_rd_wg=LFR0T&psc=1&refRID=YE1STZF4GQ0M3A077QQW Link to comment Share on other sites More sharing options...
Bootyologist Posted November 23, 2016 Share Posted November 23, 2016 fronts https://smile.amazon.com/Raybestos-H15215-Professional-Grade-Caliper/dp/B0049L6OSI/ref=pd_sbs_263_2?_encoding=UTF8&pd_rd_i=B0049L6OSI&pd_rd_r=2DJ6DHZ4S1688PF3AXNE&pd_rd_w=4zmJg&pd_rd_wg=t7nrX&psc=1&refRID=2DJ6DHZ4S1688PF3AXNE rubbers https://smile.amazon.com/Carlson-Quality-Brake-Parts-16055/dp/B000BZWWZU/ref=pd_bxgy_263_img_2?_encoding=UTF8&pd_rd_i=B000BZWWZU&pd_rd_r=YE1STZF4GQ0M3A077QQW&pd_rd_w=uQC8I&pd_rd_wg=LFR0T&psc=1&refRID=YE1STZF4GQ0M3A077QQW Where are you seeing these fit the fronts? It's still saying only they work with the rears. Sent from my XT1053 using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 23, 2016 Share Posted November 23, 2016 those are FRONT caliper pins and associated rubber parts. rear caliper pins do not have rubber sleeves. Link to comment Share on other sites More sharing options...
BoFoSho Posted November 23, 2016 Share Posted November 23, 2016 those are FRONT caliper pins and associated rubber parts. rear caliper pins do not have rubber sleeves. My 2011 2.5i has front AND rear caliper pin boots and sleeves. Advance auto has them for cheap. http://m.advanceautoparts.com/p/wearever-caliper-rubber-pin-boot-kit-18021a/3552926-P?cm_mmc=ET-_-Trans-_-Confirmation-_-General#utm_source=ET&utm_medium=Trans&utm_campaign=Confirmation&utm_content=General Link to comment Share on other sites More sharing options...
rs6er Posted November 24, 2016 Share Posted November 24, 2016 I had a similar noise. I thought it was the strut, but luckily it was only the mount. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
BoFoSho Posted November 26, 2016 Share Posted November 26, 2016 I had a similar noise. I thought it was the strut, but luckily it was only the moumy. What year legacy and how many miles we're on it? Front or rear strut mounts? Didn't you have to pull the strut to replace the mount? I assume I'll be doing this soon and plan on doing the struts and mounts all at once. Link to comment Share on other sites More sharing options...
rs6er Posted November 26, 2016 Share Posted November 26, 2016 What year legacy and how many miles we're on it? Front or rear strut mounts? Didn't you have to pull the strut to replace the mount? I assume I'll be doing this soon and plan on doing the struts and mounts all at once. It was an "07 SpecB. LF. I didn't do the work? Buy I think they had to lower the strut. I had the strut tested first buy it was working. Link to comment Share on other sites More sharing options...
MySubieII Posted November 29, 2016 Share Posted November 29, 2016 Have a 2010 GT and I've been having a noise that I thought was the right rear door. It makes noise while under acceleration and hitting bumps or backing into the driveway, especially if I hit the apron? Having suspension work done Wednesday hope this problem is remedied. I will keep posted. Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted November 29, 2016 Share Posted November 29, 2016 Have a 2010 GT and I've been having a noise that I thought was the right rear door. It makes noise while under acceleration and hitting bumps or backing into the driveway, especially if I hit the apron? Having suspension work done Wednesday hope this problem is remedied. I will keep posted. Sent from my SAMSUNG-SM-G935A using Tapatalk there was a TSB concerning the right rear pop/thunk sound. apparently some of the welds werent done as well and are redone with the TSB My "Build" Link to comment Share on other sites More sharing options...
MySubieII Posted November 29, 2016 Share Posted November 29, 2016 there was a TSB concerning the right rear pop/thunk sound. apparently some of the welds werent done as well and are redone with the TSB Thanks for the heads up. I called and they confirmed this is a known issue with 2010-2013 legacy AND outbacks. I am taking it to get it looked at next week. They seemed willing to extend to coverage of getting it fixed if in fact it is the issue. I told the lady at Subaru of America that I love Subaru, and not to make this my last one bc of an expired tsb. Thanks again! Sent from my SAMSUNG-SM-G935A using Tapatalk Link to comment Share on other sites More sharing options...
ranj1968 Posted December 20, 2016 Share Posted December 20, 2016 Can't say I am glad other people are having the same issue,,,but at least I know its an issue,,,I have the same problem on my 2000 Legacy GT for awhile now and CANNOT seem to find the problem,,,the brake caliper slide pins were not the issue, nor swaybar end links,,,I was going to the strut mounts next,,,,,did your shop find the problem?? I would be very interested on the solution..Thx Link to comment Share on other sites More sharing options...
bigboy292000 Posted December 27, 2016 Share Posted December 27, 2016 Does anyone have the number / name of the TSB for this? I want to read it to understand a bit better what is the symptom they describe. I am becoming convinced that the clunking that I occasionally hear does not come from the passenger front but rather passenger rear area on my 2011 Legacy. EDIT: I think the TSB in question is 12-147-13 or 12-147-13R. Still trying to locate it... Link to comment Share on other sites More sharing options...
TheBoltman Posted June 30, 2017 Share Posted June 30, 2017 All, here's a link to TSB 121-47-13 if you need it. http://bit.ly/TSB1214713 Link to comment Share on other sites More sharing options...
FLlegacy Posted June 30, 2017 Share Posted June 30, 2017 My noise is definitely from the front, and only happens when the wheels are turned to the right. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
MasterPeon Posted June 30, 2017 Share Posted June 30, 2017 I hear something similar from the left front side when I back out of my driveway over the curb onto the road (rear of the car going left). I also hear the same sound on the right front side when I'm turning right at low speed over sharp uneven surfaces. For me, these noises happen every single time at the same locations and no other. I've sort of learned to live with it, but I always wonder what it is. Link to comment Share on other sites More sharing options...
Loya1ty Posted September 17, 2018 Share Posted September 17, 2018 Reviving this thread. Experiencing the same clunking noise on the front right when applying the brake pedal quickly (essentially tapping). I know my bushings need replaced, and have been experiencing clunking related to those the past 2 weeks, but this sound is clearly isolated to the braking component(s) based on my described process to replicate. Almost sounds like the caliper is smacking a loose brake pad before pressing it to the rotor, since if I hit the brake slowly there is no noise. I've replaced the struts, springs, mounts, rotors, pads, and pad brackets about 8k miles ago. I did notice the caliper pistons exhibited some wear (one seemed 'gunky' when pushing and pulling). I'm going to replace the pins, new grease, and add grease to the caliper/pad plates. Car is at 155k. Link to comment Share on other sites More sharing options...
Scubaboo Posted September 17, 2018 Share Posted September 17, 2018 ^braking like that causes a lot of movement in the suspension and body and can cause a lot of things to clunk. If you have worn suspension parts I suggest sorting those out first then do the same test again. You might find the noise to be gone. Link to comment Share on other sites More sharing options...
Loya1ty Posted September 19, 2018 Share Posted September 19, 2018 ^braking like that causes a lot of movement in the suspension and body and can cause a lot of things to clunk. If you have worn suspension parts I suggest sorting those out first then do the same test again. You might find the noise to be gone. Yeah and I do experience that sometimes when braking/turning which I blame the bushings on. From what I've described above though the noise occurs noticeably before the pads start to bite. Just trying to point that out for anyone else trying to diagnose issues. I'll certainly follow up once I get under there, but I'm probably not going to do one thing at a time and test it out.. aint nobody got time for that lol just going to do it all at once. Link to comment Share on other sites More sharing options...
Scubaboo Posted September 19, 2018 Share Posted September 19, 2018 I feel you man, in chasing my own clunks I actually bought the caliper rebuild kit just to get the guide pin bushings. Didnt work in my case though. I agree with on your approach, just fix everything and hopefully it's all nice and tight after! Link to comment Share on other sites More sharing options...
