lingling1337 Posted October 22, 2012 Share Posted October 22, 2012 We're talking about those 14mm slide pin bolts right? That is what fixed my problem, replaced the lowers (without anti-seize) and torqued them down. If no one else has the part number I have it on my other computer and I can post it later today. Link to comment Share on other sites More sharing options...
jvaski1 Posted October 23, 2012 Author Share Posted October 23, 2012 Yup, them be the ones ! Link to comment Share on other sites More sharing options...
MNLegacy Posted October 24, 2012 Share Posted October 24, 2012 If anyone has the part #'s and a good spot to purchase, I'd sure appreciate having that info! Thanks! Mike Link to comment Share on other sites More sharing options...
lingling1337 Posted October 24, 2012 Share Posted October 24, 2012 26231FE011 first dealership I called had them in stock. Link to comment Share on other sites More sharing options...
MNLegacy Posted October 25, 2012 Share Posted October 25, 2012 So, I haven't took the front tires off for a while and really looked at things... But if this is just a bolt, and it is still there and tight, how does it affect the movement of the calipers or pads? Sorry for the dumb question... Mike Link to comment Share on other sites More sharing options...
trackhore Posted October 25, 2012 Share Posted October 25, 2012 So, I haven't took the front tires off for a while and really looked at things... But if this is just a bolt, and it is still there and tight, how does it affect the movement of the calipers or pads? Not dumb if you don't know what a two piece caliper looks like. Long story short, the caliper can slide back and forth over the rotor on slide pins. They're covered with a rubber boot on one end which is filled with grease. It's not uncommon for these to bind or seize up on older cars causing uneven wear issues. I've personally never experienced noise from one, but that seems to be the case here. Link to comment Share on other sites More sharing options...
jvaski1 Posted October 25, 2012 Author Share Posted October 25, 2012 Mike, here's what I got for part numbers on the dealers work order. s10 suspansion 1318 w94 2 26231FE001 Lock Pin F Brake FC: QBF20 Sorry, not sure which one of those numbers is the actual part number for the caliper pins . Link to comment Share on other sites More sharing options...
jvaski1 Posted November 11, 2012 Author Share Posted November 11, 2012 The caliper pins change definitely did the trick ................... the noise is gone ! Link to comment Share on other sites More sharing options...
MNLegacy Posted November 12, 2012 Share Posted November 12, 2012 Are these fairly easy to change? Pull out the old ones, put in the new ones? Or is it more involved? Thanks, Mike Link to comment Share on other sites More sharing options...
Jim_KT Posted November 12, 2012 Share Posted November 12, 2012 Are these fairly easy to change? Pull out the old ones, put in the new ones? Or is it more involved? Thanks, Mike If the guide and/or lock pins are not siezed it is a relatively simple replacement process. Just pull out the old ones, clean up the cavities in the caliper brackets and boots. Be sure to use a silicon grease, or any other grease that will not swell the rubber components. The rubber components to look out for are: 1) Glide and Lock Pin boots, 2) Lock Pin sleeves. Link to comment Share on other sites More sharing options...
jvaski1 Posted March 20, 2013 Author Share Posted March 20, 2013 The loud left front clunking is back ! Subaru Dealer replaced the front caliper pins a few months back and the noise went away - until now !! I phoned the dealer - and the service manager said the Subaru Rep had one other car doing same - and blew it off as a "characteristic" for someone living in Tahoe because we have rough roads.... I told the service manager to tell the Rep that this excuse isn't acceptable. We'll see if this needs to go to court for a resolution. Link to comment Share on other sites More sharing options...
formattix Posted March 23, 2013 Share Posted March 23, 2013 Still dealing with mine, as well was vibrations from the steering area Link to comment Share on other sites More sharing options...
hmmrdwn Posted March 23, 2013 Share Posted March 23, 2013 I had the same pop when going forward and backward. Shop said it's the brake pads shifting back and forth. There is "brake quiet" that needs to be applied every 15K. As the pads wear, the gap expands allowing them to come free. Subaru brakes are about as simple (but effective) as possible. There are two bolts in the back that free the caliper. The caliper comes up and the pads drop out. Apply brake quiet and lube the large pin if needed. It's got a rubber gasket and slides right out. The use a clamp on the piston and reassemble. Once you do it, you will wonder why brake shops charge so much. Link to comment Share on other sites More sharing options...
jvaski1 Posted March 23, 2013 Author Share Posted March 23, 2013 This problem seems to be associated with the front caliper pins making the noise. The dealer once greased them and the noise went away. The second time they replaced the pins and the noise went away . But the problem noise is back. I suspect either the caliper bores are oversized or the pins are undersized ( machined ) What ever the issue is - at this point it's so loud my passengers ask me what the H*ll is wrong with my car - and if we're gonna have to call for a tow.......... Link to comment Share on other sites More sharing options...
MNLegacy Posted May 8, 2013 Share Posted May 8, 2013 So I FINALLY got into mine last Friday night... My bro-in-law helped me since he has a lot more experience with this than I... We took the right one off first, and noticed a LOT of play in the slide pins. Once we had them out and cleaned them up, we noticed quite a bit of wear on the pins. It also looked like the dealer had just used "normal" yellow grease when they did this last, so that was mostly gone. It was too late to get parts from the dealer, so I called Napa and they had the pins, and new pads and some super duper grease all for $135 (about the same cost the dealer was for a "brake service" alone!). Came back home, put it all back together, extensively cleaning and liberally greasing all the areas where there is movement, and like magic, the noise is gone!!!! I really can't believe that little bit of movement can cause SO much noise in the car! But now it looks like I'll be doing a bi-yearly maintenance when I switch out the tires for winter and summer! Thanks for all the help guys! I like my Subaru again... Mike Link to comment Share on other sites More sharing options...
NKZY Posted June 6, 2013 Share Posted June 6, 2013 Sorry to dig up an old thread here but I've been experiencing this clunking noise as well. It almost sounds like the wheel is loose and seems to only occur under 25 mph or so and is most noticeable when pulling in and out of the driveway and making slow turns, etc. Has anyone else solved this problem with replacing the slide pins? It seems to be a fairly common problem judging by the initial response to this thread. It sure is driving me crazy though and I really cant figure out what else it could be?? Link to comment Share on other sites More sharing options...
GTEASER Posted June 6, 2013 Share Posted June 6, 2013 This is a 5th gen thread, but that's okay. Have you checked your sway bar end links and bushings for wear and play? Are you lowered on springs/shocks? Have you checked the upper strut mounts and strut bolts are tight? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jvaski1 Posted July 30, 2013 Author Share Posted July 30, 2013 Update - The Subaru service manager in Shingle Springs Ca just phoned me and told me the Subaru Rep refused to come listen to my front brake calipers clunking at Tahoe - and Rep has dismissed the problem as a "characteristic of Tahoe's bad roads" So I opened a case with Subaru of America and they siad they'de investigate it. The car has 23k mi on it . Next the Subaru Rep ( Larry Kelso ) decided not to even look at the car and dismiss the problem as a "characteristic of Tahoe Roads". Then Subaru of America called me and explained they closed the case dismissing it for same reason. I got hold of another person at Subaru of America after threatening a court case and she convinced this Rep ( Larry Kelso ) that he had to take a look at the vehicle. So, we're back to another trip down the hill and wasted day to have the Rep probably blow it off again. Had my local Independent Subaru Shop road test the vehicle and he agreed something was wrong - left front. NEVER again will I buy a Subaru with this kind of jerk-off warranty service ! Link to comment Share on other sites More sharing options...
BoFoSho Posted November 18, 2016 Share Posted November 18, 2016 Replacing the caliper slide pins resolved my clunking issue. The old pins had noticeable wear. Link to comment Share on other sites More sharing options...
Bootyologist Posted November 19, 2016 Share Posted November 19, 2016 Replacing the caliper slide pins resolved my clunking issue. The old pins had noticeable wear. After replacing my struts, springs, and mounts, i still have some noise up front. End links are also under 1 year old. My mechanic scoped out everything else when doing an alignment and couldnt find the source of the noise. The slide pins could be the issue. I'm going to look into this. Thank you!!! Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 19, 2016 Share Posted November 19, 2016 the issue remains with the 2014 cars. My solution will be (in the spring) to replace all of my caliper pins with aftermarket ones.... https://smile.amazon.com/Carlson-Quality-Brake-Parts-14176/dp/B000Q0EIZW/ref=sr_1_3?ie=UTF8&qid=1479583306&sr=8-3&keywords=2014+Subaru+Legacy+caliper+pins Link to comment Share on other sites More sharing options...
Timothy.B Posted November 21, 2016 Share Posted November 21, 2016 I went to price out the OEM ones and they were more than that so this is a good deal! I believe my front right caliper might be sticking a tad. Goes away after a few stops. She starts to shake n' brake a bit now too. Almost pad/rotor time. I'll get a 4 pack of these for then. Whats the recommendation for greasing up the retainers and the caliper pins? Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
DugsSin Posted November 21, 2016 Share Posted November 21, 2016 The Amazon pins has a quality brake grease shown at the bottom https://www.amazon.com/CRC-Brake-Caliper-Synthetic-Grease/dp/B000M8IF1Q/ref=pd_bxgy_263_3?_encoding=UTF8&pd_rd_i=B000M8IF1Q&pd_rd_r=5WFV4A212BJXREYRW6JD&pd_rd_w=TH2v9&pd_rd_wg=zedXT&psc=1&refRID=5WFV4A212BJXREYRW6JD Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 21, 2016 Share Posted November 21, 2016 use this stuff on any metal to metal mating surface https://www.amazon.com/Permatex-24125-Ceramic-Extreme-Lubricant/dp/B0018PSASU/ref=sr_1_3?s=automotive&ie=UTF8&qid=1479742512&sr=1-3&keywords=caliper+grease since the brackets are stainless, it is not recommended to use it on the caliper ears. the stainless will remain corrosion free Link to comment Share on other sites More sharing options...
Bootyologist Posted November 21, 2016 Share Posted November 21, 2016 the issue remains with the 2014 cars. My solution will be (in the spring) to replace all of my caliper pins with aftermarket ones.... https://smile.amazon.com/Carlson-Quality-Brake-Parts-14176/dp/B000Q0EIZW/ref=sr_1_3?ie=UTF8&qid=1479583306&sr=8-3&keywords=2014+Subaru+Legacy+caliper+pins Are these just for the rears? Amazon only lists the rear as compatible. Link to comment Share on other sites More sharing options...
