2manysubies Posted September 30, 2012 Share Posted September 30, 2012 I need some help here, taking apart my Son's EJ255(out of car) for a complete rebuild. How in the heck does one remove the 10mm camshaft gear retaining bolts? I have broken 2 "unbreakable" 1/2" drive 10mm tool's trying to get the bolts off, Cams are secure, not slipping, hard surface, even tried Impact Gun, No Joy. Anyone have any trick's?? I'm open for anything! Thanks Mac Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted September 30, 2012 I Donated Share Posted September 30, 2012 Really powerful impact gun and a 10mm hex (not Torx) bit. Been there, done that, got the T-shirt. Good luck. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 30, 2012 Share Posted September 30, 2012 Cut the bolt heads off. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
m sprank Posted September 30, 2012 Share Posted September 30, 2012 Never had one my 1/2" gun could not take off. Even though I try never to use a gun on them. Never had one more than 250ftlbs and my 1/2 bar does that. If it came down to it my 1" drive impact gun would loosen it. Link to comment Share on other sites More sharing options...
2manysubies Posted September 30, 2012 Author Share Posted September 30, 2012 Thanks, I will go to the store tomorrow to get some mew "unbreakable" tools. Just wanted to make sure I wasn't missing something stupid. I tried with a 1/2" breaker bar and a 3' pipe, Son holding engine steady, Broke 10mm snap-on bit, smashed said leverage bar into face, saw a shitload of * * * * floating around... Used impact, supposed to be 380ftlbs breakaway Q, 140psi, short hose, 20 seconds, broke the Craftsman too. Cut an Allen wrench about 2" long, tac welded in a 10mm 1/2" drive socket, impact gun, NOTHING!! Need a bigger impact gun! Mac Link to comment Share on other sites More sharing options...
holyjoetart Posted October 1, 2012 Share Posted October 1, 2012 I had one that wouldn't break loose and stripped it out. I just drilled it and used an easy out. Link to comment Share on other sites More sharing options...
compsurge Posted October 1, 2012 Share Posted October 1, 2012 I hate to ask if you've tried the timing belt trick? http://farm5.static.flickr.com/4094/4825419639_14fab35f04.jpg Link to comment Share on other sites More sharing options...
MooKz Posted October 1, 2012 Share Posted October 1, 2012 Heat up the bolt with a torch, while using the timing belt technique and then impact away my friend. Link to comment Share on other sites More sharing options...
BAC5.2 Posted October 1, 2012 Share Posted October 1, 2012 Or save yourself a lot of time and effort, and cut the bolt head off. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
compsurge Posted October 1, 2012 Share Posted October 1, 2012 I'm beginning to think I was gifted the ability to remove camshaft bolt heads with a timing belt. It was also about 30 degrees out (maybe 50-60 in the garage) so that could have played a role. Link to comment Share on other sites More sharing options...
m sprank Posted March 24, 2018 Share Posted March 24, 2018 They make proper tools so you dont have to attempt to hold the pulleys with an old belt. Also, it does not always work. Many, many times we have to weld a nut onto the end of the bolt in order to remove them. Needing propane torches is also not unusual. Outfront motorsports has probably the best You tube vid on the subject if you feel frisky. Welcome to the forum, your just about 15 years late to the party of the EJ cam bolt issues. Link to comment Share on other sites More sharing options...
boxkita Posted March 24, 2018 Share Posted March 24, 2018 Thanks, infamous, for responding to even the old threads. :-) Still taking care of us after all this time... Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
m sprank Posted March 27, 2018 Share Posted March 27, 2018 Understood. Help is always appreciated. Welcome to the forum. Link to comment Share on other sites More sharing options...
