Canister Purge Valve Location?
MY2005
I am in the process of replacing the canister purge valve (p1443 code and cant fill the gas tank). I found the vapor canister in the drivers side wheel well, but I cant seem to locate the purge valve. Vacation pics do not really show the location.
Anybody done this before? I cant find any info for 4th gens.
It's the "drain valve", not the "purge valve", the latter is found on the manifold and if that is bad you will at most get a code and nothing else.
The drain valve is an integral part of the canister according to the workshop manual.
You can also look in this thread: http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216.html
