Clutch replacement questions - 2005 Legacy GT
spritefiend
I'm looking at replacing the clutch on my 2005 LGT. I've read a few things about them and have a couple of questions.
Is converting from the dual mass flywheel, anything more than removing it and replacing it with a regular style flywheel?
Also, is anyone running an ACT SB5-HDSS & ACT Streetlite Flywheel on a stock/stage 1 map? I'm interested in this one in particular in the event I upgrade to stage 2 or any other power mods down the road, and don't want to be stuck on a stock/oem clutch setup.
Thanks!
Yes, it's that simple, use the TorxPlus 50 bit it remove the DMFW.
You should get a 07 Legacy FW which is a single mass and use it. I have a Spec LWFW, if I did it again, I'd go with a steel FW. It's easier to drive in a DD.
Engine Build - Click Here
The main difference I've felt is, it's hard to drive the car in 5th gear below 45mph. The engine feels like is lugging.
With the steel FW you can drive at 40mph in 5th with no issues.
No not really. I don't think the average person could tell. I'm pretty sensitive and have a good feel for things.
FWIW, My new Spec 2 clutch is much easier to drive than the old Spec 2+ clutch I had for 80,000+ miles.
Glad this thread came up because I have a question.
I'm looking to do a replacement on mine as well, but I'm at stage 3 18g with fuel mods and plan to have a "monthly warrior car".
I picked up a act lwfw for $60 bucks (looks brand new < 1000 miles)
just haven't decided on the clutch itself. I was looking at these two:
http://www.infamousperformance.net/servlet/the-882/ACT-Subaru-Legacy-GT/Detail
the usual:
http://www.infamousperformance.net/servlet/the-137/ACT-Subaru-Legacy-GT/Detail
There's a local shop that will buy/install the HDSS with a fluid change for $1050
I used a regular run of the mill t50 torx and impact wrench. didnt strip or damage the bolts at all torque wrench worked fine too, might work for you but the bit is like 5-10$
StageIII Cryotune-Kinugawa STS TD06H-20GTX 9 blade turbine, ID1000, DW65c, 73mm MegaMAF , GS EWG up-pipe, Downpipe and EBCS, FMS FMIC, TGV Delete, Brembo swap
the usual:
You should PM Mike and ask him what he recommends for a clutch. He'll take good care of you.
