Oil leak or normal clutch dust?
Cannonball-44
Well after many hours I finally got it apart.
Now I am starting to question if I should do more (rear seal, separator plate, ??) while I have it apart.
Anyone out there who has had their trans out.
Is this just normal clutch dust after 75k miles or am I leaking some where slightly?
There was some fluffy black build up on the rear seal which I had wiped off already.
Is there other things I should be doing while the trans is out and I have access to this area.
Will be pulling intercooler, turbo and exhaust at a later date after the new clutch is broke in. Just won't be pulling the trans any time soon.
I hope...........
Thanks for you input.
Here's mine, I had no thoughts of any oil leaking from the rear main. I did have a small leak from the right valve cover. You can also see the grease from when the left inner CV boot tore and spit grease every where, 2 years ago.
http://i185.photobucket.com/albums/x40/92Si/DSCN4726.jpg
Engine Build - Click Here
