need help with a forester
Not sure where to properly post this but i figured this was a close one. I didn't find a "other subaru" section.
I'm stilling looking for my LGT but in the mean time my uncle has a forester with a couple CEL
P0102 -Mass Air Flow (MAF) Circuit Low Input
P0113 - Intake Air Temperature Circuit High Input
P0457 Evaporative Emission Control System Leak Detected (gross leak)
Gas cap was checked, cleaned an re-tighten. Its a 09 NA forester with 80k. No work was recently done on it. MAF connector was confirmed to be plugged in and tighten. Airbox/pipe is not damaged or cracked.
Is there a way to test the MAF? Should i just go replace it, its a $200 part i think on rockauto.
What about the other 2.
