kred Posted August 18, 2012 Share Posted August 18, 2012 I have a 2005 Legacy 2.5i ltd, manual transmission. I was wondering if it was possible to install a navigation unit in the cubby hole above the radio. However, I was told by a friend that this can't be done because it would interfere with the wiring of the climate control system. Is this definitely the case? Has anyone had success with this? Link to comment Share on other sites More sharing options...
AkumaMax Posted August 18, 2012 Share Posted August 18, 2012 Well your topic title says Auto climate control(digital) if that is the case then you must buy the JDM kit for the radio it's somewhere around $380-$400 just for the kit. If it's manual controlled climate then all you need it the metra Din kit for it. Link to comment Share on other sites More sharing options...
