kirk83 Posted August 16, 2012 Share Posted August 16, 2012 Hey guys. if i upgrade my fuel pump to a deatschwerks 300LPH . Would i need a tune or will the computer see it as the oem fuel pump? Link to comment Share on other sites More sharing options...
Drift Motion Posted August 16, 2012 Share Posted August 16, 2012 correct me if I'm wrong, the flow should be regulated by the FPR Link to comment Share on other sites More sharing options...
fahr_side Posted August 16, 2012 Share Posted August 16, 2012 It depends how your car is tuned. With the factory MAF scaling the stock fuel system will not be able to hit AFRs like 10.8:1 so the values in the fuel tables will be set richer, say 10.4:1, in order to hit the actual value desired. If you upgrade the fuel pump, you'll get the value called for in the table, even if that isn't actually what you wanted. Short version, you may run richer at the bottom corner (high rpm & load) than you do on the stock pump. Other areas will be unaffected. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
