Subimods Posted August 14, 2012 Share Posted August 14, 2012 Subimods Hella Horn Bracket "The Original" http://www.subimods.com/media/catalog/product/cache/1/image/f455c0f770ff3ec09e41c373b2d24b32/7/2/72172090.png Use the link to purchase the new lower priced bracket: http://www.subimods.com/subimods-com-hella-supertone-horns-bracket.html Subimods Hella Supertone Horns Bracket THE ORIGINAL, with over 10,000 Brackets Sold, THIS IS PROVEN! Subimods.com is proud to offer the 'One and ONLY' Hella Supertone Horn Bracket for your Subaru! Designed from scratch with various designs and quality construction, we are releasing our exclusive horn bracket. Designed for an EASY install of your Hella Supertone Horns and to dress up the 'not so pretty' front grill background. This bracket takes all of the guessing and extensive time trying to figure out if your horns will end up centered, lop sided etc. This bracket takes all the fuss, all the trouble, all the headache right out of the question. Go with a product that you know will work the first time! Search online, search the forums, and see for yourself, the Subimods Hella Horn Bracket is proven! With thousands of over-satisfied customers, you too will see why this part is so popular! Do not forget our Hella Horn Wiring Harness Kit, designed to make your Hella Horn install a breeze! We also offer different powder coated colors for the Hella Horn. Why waste your time disassembling the horns and sending them out yourselves? We've done the hard work for you! Both of these additional products can be found in the Related Products section! Product Details: - Constructed of Billet Aluminum- Powder Coated Black- CNC Machined IN HOUSE (Not out sourced or from another "online facility")- Quality bends for reinforced rigidity- Sets horns in perfect mounting position- Installs in minutes!- Patent Pending!- Contact for additional powder coated colors! Fitment: - 99-01 RS/GC- 02-07 Impreza- 08-12 Impreza (must bolt in second bolt hole to prevent hood latch from rubbing)- 05-12 Legacy- Forester Notes: - Get the original Hella Horn Bracket from Subimods.com! Need a set of Hella Horns? Add them below!- Choose your Hella Horn Color!**Additional time may be required on powder coated parts, so allow 1-5 days, this is a rare case and due to a high volume demand!** NOTE: Our Hella Horn harnesses are designed to work with a standard 5 pin relay. Our harness will power the horns with a 4 pin relay but will cause the relay to stay engergized even when the car remains off causing battery drain. We can not guarantee that the relay supplied with your Hella Horns is a 5 pin relay as is required with our harness, so we have now included with every harness a standard 5 pin relay that is needed to make our harness work properly. http://www.subimods.com/media/catalog/product/cache/1/image/f455c0f770ff3ec09e41c373b2d24b32/7/4/74383224.png Link to comment Share on other sites More sharing options...
Subimods Posted August 14, 2012 Author Share Posted August 14, 2012 http://www.subimods.com/media/catalog/product/cache/1/image/f455c0f770ff3ec09e41c373b2d24b32/2/1/21840461.png Don't forget! Subimods offers it's very own Hella Horn Wire Harness! Only available at Subimods! Subimods Hella Horn Harness Kit - $35 WE CAN PACKAGE THIS WITH HORNS & BRACKET AND SAVEEEEEE!!!! Now you can easily connect your Hella Horns to your Subaru with Subimod's PLUG & PLAY WIRE HARNESS! No more leaving the relay out because of difficulty and robbing your horns of full power! Originally, when you purchased a set of Hella Horns, you receive the horns, a couple of flat stock brackets, and a relay. Oh don't forget, instructions that are forever long. You would think you would be able to purchase a product these days, and just the simple plug and play...Now you can! With over 30 years of experience in Automotive Electronics, Subimods.com has designed its very own, ORIGINAL, Hella Horn Plug & Play Wire Harness Kit. In a matter of mintues, just plug your Hella Horns in and start making some noise! Note: Subimods.com has now started including 5 pin relays with there harnesses, why? Hella includes with every set of horns a 4 pin relay, we construct our harness to only work with a 5 pin relay. If a 4 pin relay is used with our harness it could cause your horns to remain powered even when the car is off, when they should only be engergized when the horn is pushed. Any customers having this issue please contact us for a new relay Please refer to Hella's installation guide - Diagram 2b, they require a 5 pin relay for setup -There are seven connections total. The single wire goes to the factory horn wire. - The four female blue connectors go to the horns, no particular order for these. - The last two ring terminals go to your battery, ie red wire power and black wire goes to ground. Subimods Hella Horn Harness Kit Link to comment Share on other sites More sharing options...
Subimods Posted August 14, 2012 Author Share Posted August 14, 2012 http://www.subimods.com/media/catalog/product/cache/1/image/f455c0f770ff3ec09e41c373b2d24b32/h/e/hella_horns.jpg HORNS? WE GOT THEM! Most in stock, LOWEST PRICED, MOST SOLD! Don't let the copy cat(s) (only one we know of) tell you differently! $54.99 Red $65 Powder Coated FIND IT CHEAPER - I'll Beat It! Hella Supertone Horn Kit - 003399801 - Hella Link to comment Share on other sites More sharing options...
Subimods Posted August 31, 2012 Author Share Posted August 31, 2012 Get your Hella Horn Kit today, always in stock always shipping! Link to comment Share on other sites More sharing options...
Subimods Posted September 5, 2012 Author Share Posted September 5, 2012 This is a great solution, one of the first simple modifications that should be done to Subaru's to remove those old low toned stock horns! Link to comment Share on other sites More sharing options...
