Subimods Posted August 12, 2012 Share Posted August 12, 2012 Just right to the point. Find it cheaper? Let me try and beat it! Looking for additional parts or don't see something here, PM ME! http://www.jscspeed.com/images/catalog/category4801_thumb.jpg AEM Cold Air Intake (05-09 LGT) Available in Blue, Silver, & PolishedRetail: $380Sale Price: $235AEM's 05-09 Subaru Legacy GT Cold Air Intake relocates the air filter outside of the engine compartment to deliver the coolest air inlet temperatures possible. A intake heat shield gives you extra protection against engine heat and cooler air carries more oxygen which translates into a more intense explosion in the combustion chamber. These intake systems feature dry flow air filters for the best performance and almost zero maintenance. Every AEM Cold Air induction system is constructed to the highest standards and are guaranteed for the life of your vehicle. http://www.jscspeed.com/images/catalog/category4815_thumb.jpg K&N Typhoon Short Ram Air Intake (05-09 LGT) Available in BlackRetail: $470Sale Price: $235K&N is proud to introduce their Typhoon short ram intake system for the 05-09 Legacy GT. This intake features a mandrel bent aluminum intake pipe coated black and a K&N cone filter, a trusted name in performance air filtration for decades. The K&N intake system also utilizes a heat shield designed to keep ambient engine heat away from the filter, allowing for a more dense intake charge than conventional short ram intakes. This unit deletes the restrictive factory air box and is designed to increase airflow pre-turbocharger, a concept that is key to making more power in any performance vehicle. K&N has produced some very impressive numbers with their Typhoon line of intakes, gaining up to 14whp on an otherwise stock Legacy GT. All K&N products are backed by a million mile limited warranty so rest assured you are getting the highest quality product possible. http://www.jscspeed.com/images/catalog/category5226_thumb.jpg COBB SF Short Ram Air Intake (05-09 LGT) Available in Blue & BlackRetail: $195Sale Price: $195Cobb's SF Legacy GT Intake system utilizes several unique features in an effort to maintain optimal flow for performance while minimizing turbulence that can cause engine management problems. Cobb's straightener grid is specifically designed to smooth the incoming air flow as it passes the Mass Air Flow (MAF) sensor for precise readings. This eliminates the "dead spots" caused by intake turbulence. In order to provide a Legacy GT intake system that looks as good as it functions, Cobb utilized a one-piece plastic high-temperature composite plastic body. Not only does this save weight, it also prevents heat soak, keeping incoming air cooler. You will not find a more researched & developed short ram intake for your Legacy GT than the Cobb SF. http://www.jscspeed.com/images/catalog/category5228_thumb.jpg COBB SF Air Box (05-09 LGT) Available in BlackRetail: $135Sale Price: $135The Cobb Tuning SF Air Box was designed to capture the cool air supplied to the SF intake through the factory intake snorkle. The aluminum heat shield consists of a one piece surround, directional lid, and stainless fasteners that help reduce a loss of power that could be robbed from your motor by a heated intake charge. http://www.jscspeed.com/images/catalog/category22023_thumb.jpg COBB MAF Block Off Plate (05-09 LGT) Available in BlackRetail: $45Sale Price: $45The Cobb Tuning MAF Block-Off Plate Kit is the perfect complement to Speed Density tuning. Speed Density tuned vehicles use a MAP sensor instead of your Subaru's MAF sensor. Removing the MAF sensors eliminates points of restriction and turbulence in the intake tract, but it needs to be done correctly. The Cobb Tuning MAF Block-Off Plates are the easiest way to safely delete the MAF sensors for optimal performance with the added bonus of great looks. The billet 6061 T6 aluminum and CNC-machined plates seal off the openings left when the MAF sensors are removed. The kits are finished off with stainless steel button-head screws and black nylon washers that give the plates a professional appearance when installed. http://www.jscspeed.com/images/catalog/category4793_thumb.jpg K&N Drop-In Air Filter (05-09 LGT) & (10-11 LGT) Retail: $70Sale Price: $35K&N's Legacy GT replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. K&N filters are custom designed to fit into your existing factory air box for simple, fast installation. K&N stock replacement air filters for street vehicles are covered by a Million-Mile Limited Warranty. K&N Filters use oil to provide filtration, and can be washed and recharged using the K&N cleaning kit (sold separately). http://www.jscspeed.com/images/catalog/category4799_thumb.jpg Perrin Afta-MAF Silicone Hose (05-09 LGT) Available in Black & RedRetail: $85Sale Price: $70Perrin's Afta-MAF silicone air box hose for the 05-09 Legacy GT features 5-ply silicone construction and vibrant color. Replacing the stock corrugated rubber hose between the turbo inlet and factory air box will allow for improved airflow due to higher internal volume and smoother airflow due to the smooth interior. This product is the perfect compliment to a Perrin turbo inlet hose. The Perrin MAF hose is designed for use with the stock air box, but will work with any intake designed to use the stock rubber hose. Must have stock air box. http://www.jscspeed.com/images/catalog/category22815_thumb.jpg Venair MAF Hose (05-09 LGT) Available in Black, Red, Yellow, & BlueRetail: $80Sale Price: $65Treat your Legacy GT to a Venair performance MAF hose kit that will add both show and go! Venair is the global leader in the performance automotive silicone products and accessories with over 26 years of high quality manufacturing in the medical, industrial, locomotive and automotive industry. Production of all Venair performance automotive silicone kits is done exclusively in house at one of their three locations using state of the art ISO 9001, 14001 and TUV certified facilities. Venair performance silicone hose kits are application specific and guaranteed for a perfect fit and finish. The Venair MAF hose kit for the Legacy GT fits after the MAF sensor housing, connects directly to the turbo inlet and is available in red, blue, black or yellow. **Air Filter Cleaning Kits Are Also Available, CONTACT US! AIM: SUBIMODS SKYPE: SUBIMODS Link to comment Share on other sites More sharing options...
Subimods Posted September 5, 2012 Author Share Posted September 5, 2012 to the top! Link to comment Share on other sites More sharing options...
Subimods Posted December 12, 2012 Author Share Posted December 12, 2012 To the top! Link to comment Share on other sites More sharing options...
Subimods Posted January 17, 2013 Author Share Posted January 17, 2013 Blowout sale on intakes is still going down!!! Contact us today for details Link to comment Share on other sites More sharing options...
Subimods Posted January 18, 2013 Author Share Posted January 18, 2013 http://www.subimods.com/misc_images/forums/forum_header.png Link to comment Share on other sites More sharing options...
Subimods Posted January 21, 2013 Author Share Posted January 21, 2013 Let your leggy breathe a little easier TODAY!!! Let us know what we can do for you! Link to comment Share on other sites More sharing options...
Subimods Posted January 22, 2013 Author Share Posted January 22, 2013 Other intakes are available even if not listed!!! PM us today to check availability Link to comment Share on other sites More sharing options...
Subimods Posted January 23, 2013 Author Share Posted January 23, 2013 is there any way i can get just the bracket/heat shield for the AEM? Sorry but no, the bracket/heat shield are only available along with the intake in as a kit. Link to comment Share on other sites More sharing options...
Subimods Posted January 28, 2013 Author Share Posted January 28, 2013 All intakes listed are still on sale and ready to ship!!! Link to comment Share on other sites More sharing options...
Subimods Posted February 7, 2013 Author Share Posted February 7, 2013 PM's replied on fitment and combo deals Link to comment Share on other sites More sharing options...
Subimods Posted February 11, 2013 Author Share Posted February 11, 2013 http://www.sb-innovation.de/members/anon-albums-misc-iii-picture11479-cats-bump.jpg Link to comment Share on other sites More sharing options...
Subimods Posted February 12, 2013 Author Share Posted February 12, 2013 PM's replied Link to comment Share on other sites More sharing options...
Subimods Posted February 13, 2013 Author Share Posted February 13, 2013 All PM's replied, intake and other packages quoted Link to comment Share on other sites More sharing options...
Subimods Posted February 15, 2013 Author Share Posted February 15, 2013 Intakes and drop in filters are shipping out by days end Contact us for all your short ram, cold air, drop in panel filter needs!!! Link to comment Share on other sites More sharing options...
Subimods Posted February 20, 2013 Author Share Posted February 20, 2013 All intakes still available Link to comment Share on other sites More sharing options...
Subimods Posted February 25, 2013 Author Share Posted February 25, 2013 Cobb intakes/boxes shipped!!! Link to comment Share on other sites More sharing options...
Subimods Posted February 27, 2013 Author Share Posted February 27, 2013 Looking for something that will help your engine breath alot better than the stock air box?!?! PM us today and we can help get you headed in the right direction Link to comment Share on other sites More sharing options...
Subimods Posted March 6, 2013 Author Share Posted March 6, 2013 PM's replied on all your intake needs Link to comment Share on other sites More sharing options...
Subimods Posted March 12, 2013 Author Share Posted March 12, 2013 All PM's replied, if you don't see it listed then just shoot us a PM and we will see what we can do to help Link to comment Share on other sites More sharing options...
Subimods Posted March 22, 2013 Author Share Posted March 22, 2013 PM's replied in regards to different intake options If you don't notice the intake you're looking for listed then just PM us and we can see what options we have available! Link to comment Share on other sites More sharing options...
Subimods Posted March 28, 2013 Author Share Posted March 28, 2013 http://img.techpowerup.org/110714/bump%20meme.jpg Link to comment Share on other sites More sharing options...
Subimods Posted April 3, 2013 Author Share Posted April 3, 2013 All PM's replied, Cobb short rams w/ air boxes shipped out Link to comment Share on other sites More sharing options...
Subimods Posted April 16, 2013 Author Share Posted April 16, 2013 PM's replied, while doing the intake it is also a good idea to do the turbo inlet and after maf tube aswell!!! PM us for details if you're interested Link to comment Share on other sites More sharing options...
Subimods Posted April 17, 2013 Author Share Posted April 17, 2013 Full GrimmSpeed line available at Subimods, PM us for pricing on the GrimmSpeed EBCS Link to comment Share on other sites More sharing options...
Subimods Posted April 18, 2013 Author Share Posted April 18, 2013 PM's replied, days end bump Link to comment Share on other sites More sharing options...
