DiegoM Posted August 10, 2012 Share Posted August 10, 2012 What could cause the EGR too malfunction ? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted August 10, 2012 Share Posted August 10, 2012 Check ALL the vacuum lines and if they are all in good working order, check the EGR pressure sensor on the passenger side strut tower. Link to comment Share on other sites More sharing options...
Lsnaple Posted August 10, 2012 Share Posted August 10, 2012 Probably a vacuum hose popped off its connection or has a leak. Remember if something just popped off and you put it back on the ecu needs you to drive like 50 miles before it clears. Link to comment Share on other sites More sharing options...
twisty Posted August 10, 2012 Share Posted August 10, 2012 i get that code intermittently due to breaking off one of the vacuum lines at the canister by the radiator. its annoying, but it goes away within 30 miles of driving. i could fix it, but its hot outside. really hot. like 115 hot. Link to comment Share on other sites More sharing options...
DiegoM Posted August 10, 2012 Author Share Posted August 10, 2012 Alright thanks I will check tomorrow since right now its raining a lot Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 11, 2012 I Donated Share Posted August 11, 2012 Bad EGR valve, blocked EGR tube, vacuum leak, bad control solenoid -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
