mathewsdevil Posted August 10, 2012 Share Posted August 10, 2012 So the 2.5L engine in my 1997 Legacy Outback has kicked the bucket all due to overheating. I know the EJ25s from '96-'99 are notorious for this and was wondering - is it possible to put a 2000/2001/2002 2.5L engine in my '97? If so, what would it entail? I'd like to replace the engine and know that the issues were fixed in the newer years plus these year engines aren't as expensive. All help is appreciated! Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 10, 2012 Share Posted August 10, 2012 Just rebuild an EJ25D from a junkyard. If you replace the gaskets and make sure all of the mating surfaces are flush, it should carry you another 100k miles (assuming your mechanics are all good). If I'm not mistaken, the newer 2.5s are SOHC, so it seems like it should just drop in place of your DOHC with a little fab work. I don't know about anything but the EJ25Ds though so don't listen to me. lol Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 10, 2012 Share Posted August 10, 2012 Found some info on Wikipedia. Apparently the EJ251 has the same HG leak issue. The EJ251 was used in Imprezas, Outbacks, Legacys, and Foresters from 00-04. Also, it is SOHC. Link to comment Share on other sites More sharing options...
johnegg Posted August 10, 2012 Share Posted August 10, 2012 is it possible to put a 2000/2001/2002 2.5L engine in my '97? not easily. with enough time and money you can do anything, even put a small V-8 on a motorcycle. but there are easier swaps for the 97 subaru. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted August 10, 2012 Share Posted August 10, 2012 You can use later year EJ251/3s but you need to remove the crank gear, crank sensor, cam sensor, intake w/it's wiring harness, knock sensor, & the cylinder heads from the 251/3 & replace them with those from your 25D. The 25D heads will bolt right on & that combo should create a higher compression engine. Just assemble it with new seals/MLS head gaskets as you would a 25D & you should be good. Link to comment Share on other sites More sharing options...
taylormac1993 Posted August 12, 2012 Share Posted August 12, 2012 You can use later year EJ251/3s but you need to remove the crank gear, crank sensor, can sensor, intake w/it's wiring harness, knock sensor, & the cylinder heads from the 251/3 & replace them with those from your 25D. The 25D heads will bolt right on & that combo should create a higher compression engine. Just assemble it with new seals/MLS head gaskets as you would a 25D & you should be good. Which ECU should he use? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted August 12, 2012 Share Posted August 12, 2012 Which ECU should he use? 25D ECU should be used. Link to comment Share on other sites More sharing options...
johnegg Posted August 13, 2012 Share Posted August 13, 2012 the one that came with the car. the ecu has to match the harness. when they move pins on the ecu, the change the harness to match. Link to comment Share on other sites More sharing options...
twisty Posted August 13, 2012 Share Posted August 13, 2012 with enough time and money you can do anything, even put a small V-8 on a motorcycle. http://arizonabosshoss.com/new-images/home-page-images/image1.jpg Link to comment Share on other sites More sharing options...
twisty Posted August 13, 2012 Share Posted August 13, 2012 oh sorry, you said small v8... Link to comment Share on other sites More sharing options...
mathewsdevil Posted August 19, 2012 Author Share Posted August 19, 2012 I appreciate all of the responses but I have found a wonderful deal on a 2.5L out of a '96. It's in great shape and the price was right. Again, thanks for all of the advice (or lack there of). Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted August 20, 2012 I Donated Share Posted August 20, 2012 Found some info on Wikipedia. Apparently the EJ251 has the same HG leak issue. The EJ251 was used in Imprezas, Outbacks, Legacys, and Foresters from 00-04. Also, it is SOHC. They do have a head gasket issue, but its no where near as serious as the EJ25D. The EJ251 leaks coolant EXTERNALLY (While the 25D is internal). You can pick up a coolant additive from the Subaru dealer that fixes the problem for you. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
