Help Finding A Thread....
I've searched a million times. There was someone on our thread who has a BD/BK Legacy and it was a automatic. He later swapped the 4EAT from his car and did a 5MT swap. I had it saved under my favorites for links but my old computer crashed.
Anyone have any idea who it maybe on the boards? Pretty sure his car was either green, black or white. Pretty sure what I remember about that thread was it was his member journal or whatever. Please help, I am bout to go thorugh the same about of work he has done and he had alot of info and pics. Thanks in advance.
Really each swap is different
From type of clutch to final drive to wireing.
I did it myself in an auto 97 and the guts from a 95 cable clutch car.
I needed the subframe
Rear diff
Drive shaft
Transmission of course
Clutch and flywheel
shifter
Interior piece
Pedal assembly and fork
And well wireing is another animal in my car.
Only senor used on the tranny was the speed sensor which snapped right together
Dont ask about wireing cause I cant help. If you press the starter in my car the motor will turn over as long as the battery is in. No fail safe. The wire goes from the key to the starter
Sent from my Galaxy Tab using TapaTalk 2
