Heat - A/C stopped working
Well, like the title says. I have a '92 Legacy Wag, and on all settings the blower motor will not do nothing. I replaced the motor with a junk yard one to try and save 70 bucks. Still nothing. I'm not sure if this is normal, but the electric fan is blowing when the heat/ac is turned on.
Any help would be great.
Bryan
I'm pretty sure it's your ac panel. That black square
on your dash to the right of the steering wheel above
the cigarette lighter port. Remove it and play with the
connector that's back there. If it turns on then it's
probably that connector. If it doesn't you could pull
the AC panel and see if some of the solders are bad.
Yours has a height adjustment button
next to the steering wheel? Pics?
I dont know crap about voltage or really
anything electrical. I mainly do stuff by
messing with connectors if something's
not functioning properly like that. Is .24
a bad rating?
What is the height button even for? I will work on getting a picture, if it will help.
I replaced all 4 relays in the engine compartment and still nothing.
.24 seems real low to me. I would think the fan would need closer 2 12 volts to run, rather then .24
Bryan
I would assume something to do with an air
ride suspension or maybe a headlight height
adjuster, but I've always had the standard
struts so I didnt even know the US models
came with anything in that port. Does the
button seem to do anything? Pics probably
wouldn't help, but I'm curious about it. I'll ask
my friend Bryan. He knows a lot more about
electrical work than me.
  • 1 month later...
Replace your AC fuses big black ones under the Hood and up above your fuse box inside the car. Replace them all to be safe. Mine did the same thing. And the height button is to adjust. Your front struts height for off road. They are garbage tho I just pulled them out and put aftermarket struts way better.
