DoDo1975 Posted August 1, 2012 Share Posted August 1, 2012 What gaskets will I need to do a short block swap. Since the short block gaskets are already in place, is there many; or just a few. Am I better off just buying the overhaul gasket set? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 1, 2012 Share Posted August 1, 2012 You buy the gasket set for the year of the heads. That's what bmx045 told me when I put the new ej257 in my 05. Hint the set doesn't have all the pieces. check my thread, "Got some new stuff for engine R&R" it's in this forum. found it, http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
bmx045 Posted August 1, 2012 Share Posted August 1, 2012 you buy the gasket kit for your model year car. even if you buy a shortblock assembled you'll still need a good amount of the ones included in the kit. so yes, i 110% recommend buying the kit. you'll need new cam seals, head gaskets, valve cover gaskets, etc.... the list goes on. Link to comment Share on other sites More sharing options...
PeterJMC Posted August 1, 2012 Share Posted August 1, 2012 If you are still confused as to what you need... Call FredBeansParts to fill in the blanks Link to comment Share on other sites More sharing options...
wurkenman Posted August 2, 2012 Share Posted August 2, 2012 get an oil pan gasket too. Not included in a COMPLETE kit. WTF. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
bmx045 Posted August 2, 2012 Share Posted August 2, 2012 Thats because an oil pan gasket doesnt exist you're suppose to use fuji bond like what came on the original block Link to comment Share on other sites More sharing options...
InnocentGuns Posted August 2, 2012 Share Posted August 2, 2012 I cant believe how much parts for these motors cost... gaskets 180, head studs 150, pistons 175, oil pump with gates kevlar timing belt kit 400, airfilter, plugs, oils. ect. more than most complete motor just to rebuild.. Link to comment Share on other sites More sharing options...
bmx045 Posted August 2, 2012 Share Posted August 2, 2012 Yes? Go on... I have 6k miles on my 2012 ej257 with weisco pistons Link to comment Share on other sites More sharing options...
InnocentGuns Posted August 2, 2012 Share Posted August 2, 2012 I wish everyone who rebuilds these babys a long and prosperous life.. and dodo1975 make sure you get a munaul with all torque specs and tolerances. Link to comment Share on other sites More sharing options...
bmx045 Posted August 2, 2012 Share Posted August 2, 2012 The quality of your tune plays as crucial of a role on longevity as does doing proper oil changes. Link to comment Share on other sites More sharing options...
wurkenman Posted August 2, 2012 Share Posted August 2, 2012 I cant believe how much parts for these motors cost... gaskets 180, head studs 150, pistons 175, oil pump with gates kevlar timing belt kit 400, airfilter, plugs, oils. ect. more than most complete motor just to rebuild.. Wait til you want power. You will be happy with what you just spent on a rebuild. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 2, 2012 Share Posted August 2, 2012 I cant believe how much parts for these motors cost... gaskets 180, head studs 150, pistons 175, oil pump with gates kevlar timing belt kit 400, airfilter, plugs, oils. ect. more than most complete motor just to rebuild.. That's why some of us chose to do a new OEM EJ257 short block for $1800. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
