quick4dr Posted July 30, 2012 Share Posted July 30, 2012 Will 08lgt seats bolt into an 05 LGT? Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 30, 2012 I Donated Share Posted July 30, 2012 This is hardly urgent. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
PeterJMC Posted July 30, 2012 Share Posted July 30, 2012 They should. There is no mention of a redesign in positioning or mounting of front seats from '05-'08. The wiring harness might be different from a '08 to a '05 Link to comment Share on other sites More sharing options...
PeterJMC Posted July 30, 2012 Share Posted July 30, 2012 One ADDITIONAL thing to note.... '05 rear seats ARE NOT split fold down. '08 rear seats ARE split fold down. You will need to do some modification to the interior rear seat framing if you plan on installing '08 rear sedan seats. I know that there is a How-To on the forum somewhere. My attempt in searching to find it has been unsuccessful so far. Link to comment Share on other sites More sharing options...
05 LegacyGT Posted July 30, 2012 Share Posted July 30, 2012 This is hardly urgent. What do you expect him to do, stand up while he's driving? Link to comment Share on other sites More sharing options...
quick4dr Posted July 30, 2012 Author Share Posted July 30, 2012 So I have to fabricte the rear, the fronts might have different harness Link to comment Share on other sites More sharing options...
PeterJMC Posted July 30, 2012 Share Posted July 30, 2012 So I have to fabricte the rear, the fronts might have different harness In short, yes you got it. Fronts. Should bolt in. Wiring harness might be different. Rears. Will require you to grind down some brackets on your vehicle which support your current rear seats. You will not need to modify the '08 seats to fit. Link to comment Share on other sites More sharing options...
05 LegacyGT Posted July 30, 2012 Share Posted July 30, 2012 The spec.B got memory seats for 07-09 so there's a good chance the harness will be different to accommodate that. Link to comment Share on other sites More sharing options...
PeterJMC Posted July 30, 2012 Share Posted July 30, 2012 Spent a bit more time doing some searching for you and found these threads. Good luck with the modding! Looks like you will need a few other parts such as brackets, and trim. If you are taking the seats out of a donor car maybe you can pick those parts up too or else you'll have to buy these from the dealer. The walk through thread below has the details on the parts and part numbers. Walk Through http://legacygt.com/forums/showthread.php/07-spec-b-interior-swap-into-05-125937.html?t=125937 http://legacygt.com/forums/showthread.php/07-spec-seats-05-lgt-54778.html?t=54778 Link to comment Share on other sites More sharing options...
