NavigatorsLegacy Posted July 27, 2012 Share Posted July 27, 2012 I recently upgraded some of my lights in my 2011 Legacy because I like the bright white LED look for license plate and trunk light. Wow! Bright! I had no issues installing these. What I need is your expertise in solving the following issue:[/color][/b] When I went to try to change my Back up Light bulbs I couldn't. It may have been the Heat &Humidity and my impatience fuddling around after I removed the kick Panel in the trunk on the back of the light housing. I tried jamming my XL hands in many different ways to gain access to the bulb. Am I missing a step? Is there a tool I need? I by no means am a mechanic but I like to think of myself as someone who can cover the basics. Can anyone provide me with suggestions on how best I can Remove this to gain access to the bulb to swap out for LED bulbs I have? Link to comment Share on other sites More sharing options...
.Catalyst. Posted July 27, 2012 Share Posted July 27, 2012 Maybe it's different in the 5th gen but I did mine in literally 45 seconds (including opening the packaging they came in). On the 4th you unclip the cover, twist the bulb socket about 30 degrees and pull out - reverse the procedure to put it back together. My spec.B [#163] Project Thread with Pictures Get CryoTuned! Link to comment Share on other sites More sharing options...
NavigatorsLegacy Posted August 1, 2012 Author Share Posted August 1, 2012 Thanks. I got it. Link to comment Share on other sites More sharing options...
