cat back question
ir2005
So last week I bought a 2005 lgt. It came with a catless dp and cat back that I had to install. None of the pipes had markings as to who made them. I put them on and it all sounds good! fitment was a little janky...
I noticed at the y pipe to the mufflers its goes from 3 inch to 2.25 which seems a little small. The exhaust has a little raspyness to it. Would that because its going from 3 to 2.25? or just crappy made Chinese mufflers?
I believe this is the exhaust
http://www.ebay.com/itm/DUAL-4-TIP-OVAL-MUFFLER-MIDPIPE-CAT-BACK-CATBACK-EXHAUST-05-09-SUBARU-LEGACY-GT-/190706449829?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c66fd7da5&vxp=mtr#ht_4222wt_1397
The gentleman said he got it off ebay and it was less than $350. So im guessing its that.
(the only good thing it does it makes the turbo whistle really loud)
1) it's not a restriction
2) yes, it's probably because the catback is ghetto
3) i hope you have a tune for the car but you probably don't. you'll be sorry if you don't get one very, very soon and lay off the gas.
I just got the car this way a week ago so I dont know much other than what i have read and this is pretty small from all the other exhausts i have looked at from the y pipe back. its going in tomorrow for a tune.
The smaller pipes from the Y back is fine, in theroy you have the exhaust gasses cut in half so you don't need 3" on each side.
Hopefully you have a catless up pipe on the car ?
Engine Build - Click Here
