LegacyKid5 Posted July 16, 2012 Share Posted July 16, 2012 So I'm looking at picking up some Spec B struts with Tein H tech springs fo rmy 05 LGT wagon currently on stock suspension. I'm looking to slightly lower my car and improve handling without making the ride too harsh as it is my daily driver. My question is how much of an improvement in comparisson will this setup offer over stock and in the future if I were to run an 18 inch wheel, I shouldn't have any issue rubbing with a 225/40/18 tire and with a 1/2 saggy butt spacer in the bag should I be pretty even in the drop? Thanks in advance. Link to comment Share on other sites More sharing options...
LegacyKid5 Posted July 17, 2012 Author Share Posted July 17, 2012 Just for reference, in the future I'm planning to run the 18x8 Rota Gravel. So with that size wheel and offset, will I see any issues? Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 17, 2012 Share Posted July 17, 2012 You should be fine. Personally I'd opt for Koni's over the specB struts though. Adjustable rebound and better valving. Link to comment Share on other sites More sharing options...
LegacyKid5 Posted July 17, 2012 Author Share Posted July 17, 2012 The only reason I was looking at the specB struts was that I have a pretty good deal on a set with the tein h tech springs, top hats and saggy but spacers all put together. Would you say there is quite a bit of difference? Link to comment Share on other sites More sharing options...
whitetiger Posted July 17, 2012 Share Posted July 17, 2012 yes, konis are much better than stock spec b units. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted July 17, 2012 Share Posted July 17, 2012 What about Tokico? Link to comment Share on other sites More sharing options...
whitetiger Posted July 17, 2012 Share Posted July 17, 2012 koni is generally a better damper than tokico. i personally dont have alot of experience with tokico, and only a few members have had them and reviews have been mixed. I do know that they need spec b top hats and assorted hardware. Link to comment Share on other sites More sharing options...
Nrw Posted July 18, 2012 Share Posted July 18, 2012 I know I was unimpressed with the tokicos I had on my last car. I was always jealous of my buddies re-valved koni's and ground control coilovers. I have Koni's on my LGT now and love them. Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted July 18, 2012 Share Posted July 18, 2012 What do you do if you want koni's but don't want to hack up your struts? Thats the biggest reason i'm put off in getting a set. I have no work space so i have to take nearly everything to my mechanic, who doesnt like jobs that arent bolt on / drop in. Link to comment Share on other sites More sharing options...
robitrice Posted July 18, 2012 Share Posted July 18, 2012 a knowledgeable mechanic or machine shop should be able to to the Koni install. I would easily do them as the amount of work is minimal but you dont get any sort of warranty or anything if you do it yourself....if you screw up it is on you. The reviews on Koni's are impeccable and there is a good reason why people use them. I cannot wait to get mine Link to comment Share on other sites More sharing options...
Nrw Posted July 18, 2012 Share Posted July 18, 2012 Cutting the front struts is easier than it sounds. Link to comment Share on other sites More sharing options...
whitetiger Posted July 18, 2012 Share Posted July 18, 2012 What do you do if you want koni's but don't want to hack up your struts? Thats the biggest reason i'm put off in getting a set. I have no work space so i have to take nearly everything to my mechanic, who doesnt like jobs that arent bolt on / drop in. some places like AZP installs IIRC sell pre-assembled units for alittle extra $$$ or maybe core charge return. that way you get fully install-able units for your mechanic. Link to comment Share on other sites More sharing options...
Heedz Posted July 24, 2012 Share Posted July 24, 2012 took us an hour and a half to install konis, cutting and everything included. It's really simple. Also, paired on swifts. I love the set up. Link to comment Share on other sites More sharing options...
