CRAZY KEN Posted July 16, 2012 Share Posted July 16, 2012 based on these specs from OEM to aftermarket...will this wheel and tire combo fit? Do I need to roll out the fenders or shave my liner? Thanks, CK P.S. I have RCE Tarmac 3 Coilovers on... Link to comment Share on other sites More sharing options...
CRAZY KEN Posted July 16, 2012 Author Share Posted July 16, 2012 are our OEM 18" x 7" wheel +52mm offset? CK Link to comment Share on other sites More sharing options...
froggert Posted July 16, 2012 Share Posted July 16, 2012 my guess is that it will fit but you'll have to roll the fenders. there should be no problems with inboard clearance. i'm currently running 245/40-18 on 18x9.5" +38mm offset wheels and stock suspension. no rubbing, but only have about a centimeter of clearance between the tire and the strut. hopefully the racecomp coilovers i ordered will show up soon. Link to comment Share on other sites More sharing options...
minuccims Posted July 18, 2012 Share Posted July 18, 2012 are our OEM 18" x 7" wheel +52mm offset? CK KrazyK - OEM rims are 18" x 7.5" +55 offset; the size is cast into the rims. It's a typo in the brochures. I'm running 18x9s +35 offset, 245/40R18 on RCE Blacks, OEM struts/shocks. No rubbing. at +30 you will need to roll and pull if you will have coil overs and lower. http://legacygt.com/forums/picture.php?albumid=944&pictureid=4974http://legacygt.com/forums/picture.php?albumid=944&pictureid=4978 Link to comment Share on other sites More sharing options...
