Max Capacity Posted August 15, 2012 Share Posted August 15, 2012 Totally depends how RPM's when driving. I will average anywhere from low 10's to high 20's. When I first went stage 2 I thought something was wrong....turns out I was just having more fun! Yep, been there, done that. I find I have to stay off the back roads... LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted August 15, 2012 Share Posted August 15, 2012 Just filled up, 15.5gal. 374.6 miles = 24.16 MPG Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 16, 2012 Share Posted August 16, 2012 282.7 miles 11.970 gallons = 23.6 mpg 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
dr_sharp Posted August 16, 2012 Share Posted August 16, 2012 190mi / 13.2gal = 14.4mpg http://legacygt.com/forums/attachment.php?attachmentid=125952&stc=1&d=1345080242 lol Link to comment Share on other sites More sharing options...
jschuk Posted August 16, 2012 Share Posted August 16, 2012 My driving varies between 5700-5400ft elevation (my commute is 5730->5410->5820 over 8.5 miles), and in the burbs traffic flows decently with not too much stop-n-go. I fill my tank to full plus two more pump clicks, and drive it just below the E. 2009 OBXT 5MT, factory RE92@2psi over recommended. I keep up with traffic and drive in the left lane if I can help it, but I am not driving like an a-hole. I do coast to stoplights, and down hills. Lately I haven't been that fast off the line as I have been trying to see how good of mileage I can get, plus I am taking it easy on the new shortblock/turbo. I almost always have the car in I and will use S# to pass. Date Cpu-Mpg Act-Mpg 4/19/12 23.7 23.8 18709 odometer miles 5/10/12 23.1 23.1 6/14/12 24.3 24.2 6/22/12 24.0 24.8 topped off tank for trip, 4.838 gallons 6/22/12 21.3 21.8 cruising 85-93 mph (headwind) 6/24/12 21.0 22.7 cruising 85-93 mph (headwind) 6/24/12 24.3 24.5 cruising 85-93 mph (tailwind) 6/28/12 23.4 22.8 cruising 90-95 mph (tailwind) 7/19/12 24.0 23.6 21556 odometer miles 8/5/12 24.6 24.1 21919 odo miles at fill-up, new shortblock at 21760 8/15/12 so far 25.2mpg on 261.5 miles of driving Interesting read about pump accuracy. I know this one gas station that always pumped 15.5-16.0 gallons on what should have been a 15.25-15.5 gallon fill-up so I stopped using it (even though their prices were always .02-.03 cheaper). I ended up finding out that another person complained about that same gas station. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 16, 2012 Share Posted August 16, 2012 190mi / 13.2gal = 14.4mpg http://legacygt.com/forums/attachment.php?attachmentid=125952&stc=1&d=1345080242 lol Link to comment Share on other sites More sharing options...
fysics Posted August 16, 2012 Share Posted August 16, 2012 Interesting read about pump accuracy. I know this one gas station that always pumped 15.5-16.0 gallons on what should have been a 15.25-15.5 gallon fill-up so I stopped using it (even though their prices were always .02-.03 cheaper). I ended up finding out that another person complained about that same gas station. I'm not an expert but I am in the fueling/compliance industry. Every pump/dispenser has a meter in it which depending on state/federal laws should be calibrated every 6-9months or so. Usually these things are dialed-in fractions of a percent of a gallon, but it can go either way giving you more gas or dispensing less than reported. Also most US dispensers max out at 10 gallons/min of dispensing, never really hitting that. If you go to pump and it's flowing slowly that's a clogged fuel filter, again something supposed to be replaced often but something that is seldom done. /End boring info rant Link to comment Share on other sites More sharing options...
Pako Posted August 19, 2012 Share Posted August 19, 2012 169 miles and just filled up for 13.8 MPG as the calculator displays. ECU shows 13.2 MPG however... Lots of spirited driving. Link to comment Share on other sites More sharing options...
a93x Posted August 19, 2012 Share Posted August 19, 2012 246 mi 15.5 gal = 16.4 mix of City and highway while driving extra conservative torque impresses girrls, hp impresses flat-bills Link to comment Share on other sites More sharing options...
JWA2008LGT Posted August 19, 2012 Share Posted August 19, 2012 Went Stage 3 recently and (I believe) the associated tune is giving me better mileage. I went from 23-25 (hwy) to 25-26.5... It's only been a few tanks, but I notice a difference. I also notice the biggest thing to affect the mileage is my right foot... Link to comment Share on other sites More sharing options...
blazeWRX2002 Posted August 19, 2012 Share Posted August 19, 2012 I average around 25.5... I think the real question is the fual to air ratio. Saubaru's run rich from the factory about 14.7. With mine dialed in at 15.2 it is much better while cruising. Link to comment Share on other sites More sharing options...
1454 Posted August 19, 2012 Share Posted August 19, 2012 I average around 25.5... I think the real question is the fual to air ratio. Saubaru's run rich from the factory about 14.7. With mine dialed in at 15.2 it is much better while cruising. Since when is 14.7 considered "rich". I know one can run leaner than that safely, but of course the factory isn't going to do that. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted August 19, 2012 Mega Users Share Posted August 19, 2012 Try running 15.2 under load...then replace engine when it assplodes. Link to comment Share on other sites More sharing options...
blazeWRX2002 Posted August 20, 2012 Share Posted August 20, 2012 it only cruises at 15.2... under load it is much richer duh! Link to comment Share on other sites More sharing options...
xt2005bonbon Posted August 28, 2012 Share Posted August 28, 2012 Just came back from a dowhill mountain biking slash camping trip. Drove a total of 1100 miles. Average speed on freeway: 67 mph speed. Got like 20 mpg with two fairly big bikes on the roof . I did an interesting test though: I was behind a tall RV driving around 70 mph for about 5mn. My mpg average was around 24-26!! As soon as the RV exited the freeway, went back to 20 at the same speed!! Crazy. This is probably my last trip with bikes on my roof. Link to comment Share on other sites More sharing options...
gimpydingo Posted August 28, 2012 Share Posted August 28, 2012 Calc at the pump today, 18.2 with a mix of city, highway stop and go and mountain driving. Link to comment Share on other sites More sharing options...
Kookookachew Posted August 28, 2012 Share Posted August 28, 2012 May have broken a record with the LGT. On a mostly highway drive ~70 mph on my way back to school with the car loaded full of college stuff I managed a blistering 35.66 MPG!!!! Interestingly enough my trip computers readout after the trip was 31.5, but when I filled up in town at school I calculated it to be 35.66! And the trip wasn't entirely smooth either, at one point driving through Fort Drum NY and Canton NY I had to deal with construction traffic jams. (About 15 mins each). I've included some pictures, both of the trips Avg. Readout with the trip in the picture, and a pic of the gas receipt after filling up. Just so you guys dont think I'm full of it... Link to comment Share on other sites More sharing options...
Pako Posted August 28, 2012 Share Posted August 28, 2012 ^ That's incredible! My last take averaged 14.22 mpg. I was in S# most of the time. I am trying to run in Intelligent mode on the Si-Drive this tank to see if I can break 20 mpg. This is all around town driving, no HWY miles. Link to comment Share on other sites More sharing options...
mattg Posted August 28, 2012 Share Posted August 28, 2012 18.5 for my last in town tank Link to comment Share on other sites More sharing options...
quick4dr Posted August 28, 2012 Share Posted August 28, 2012 18 or so around town depending how happy my right foot is but over 25 on highway tanks Link to comment Share on other sites More sharing options...
Lawson Posted April 19, 2013 Share Posted April 19, 2013 i averaged 16.8 mpg on my last tank, 90% city. driving like a complete jerk... when i took it on the freeway i was getting about 24 mpg so overall im happy it's not bad when im driving like a sane man. Link to comment Share on other sites More sharing options...
derp Posted April 19, 2013 Share Posted April 19, 2013 I ususally average 23 to 24. At the driving event I averaged 11. On my road trip the best I saw was a tank of 28 mpg. I could suck start a snow blower. Link to comment Share on other sites More sharing options...
rob-2 Posted April 19, 2013 Share Posted April 19, 2013 May have broken a record with the LGT. On a mostly highway drive ~70 mph on my way back to school with the car loaded full of college stuff I managed a blistering 35.66 MPG!!!! Interestingly enough my trip computers readout after the trip was 31.5, but when I filled up in town at school I calculated it to be 35.66! And the trip wasn't entirely smooth either, at one point driving through Fort Drum NY and Canton NY I had to deal with construction traffic jams. (About 15 mins each). I've included some pictures, both of the trips Avg. Readout with the trip in the picture, and a pic of the gas receipt after filling up. Just so you guys dont think I'm full of it... I like it. For whatever reason I find that unless you get close to 10 gal there isn't a good measure FYI if your computer and actual are off its a cheap way to determine your I injectors need cleaning. Link to comment Share on other sites More sharing options...
uncle humjaba Posted April 19, 2013 Share Posted April 19, 2013 My computer is about 1mpg optimistic. I usually get about 21mpg driving from school and back (about 5 miles of 40mph, with 4 stop lights). 25 on the freeway (60-80mph) and teens when I'm greedy Link to comment Share on other sites More sharing options...
2_point_5_GT Posted April 19, 2013 Share Posted April 19, 2013 16.8 with minimal highway driving (less then 5 miles before my exit)...took a trip to North Carolina to see my buddy in the Marine Corps and it was 25.4...not too bad. Link to comment Share on other sites More sharing options...
