Kodax Posted July 15, 2012 Share Posted July 15, 2012 Hey guys, I am moving into the next phrase of my project for my car. So, I have been doing some research but it hasn't yield any much result. I was hoping that you N/A gurus could help me out here. I am wondering if there are anyone making high flow cats for our 3.0R or does the LGT high flow cats fit our cars? Link to comment Share on other sites More sharing options...
lee07 Posted July 15, 2012 Share Posted July 15, 2012 Should fit, if not always a custom exhaust shop that will do it for you Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 15, 2012 Share Posted July 15, 2012 Hey guys, I am moving into the next phrase of my project for my car. So, I have been doing some research but it hasn't yield any much result. I was hoping that you N/A gurus could help me out here. I am wondering if there are anyone making high flow cats for our 3.0R or does the LGT high flow cats fit our cars? Headers yes , HFC not so much . All the HFC ive seen have been custom made for the EZ30/6 and EG33. You can have a cat section fabbed up for a decent price. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 15, 2012 Mega Users Share Posted July 15, 2012 Or just gut the cat... Link to comment Share on other sites More sharing options...
Kodax Posted July 15, 2012 Author Share Posted July 15, 2012 Headers yes , HFC not so much . All the HFC ive seen have been custom made for the EZ30/6 and EG33. You can have a cat section fabbed up for a decent price. Do you have any ball park range for the cat? Also, if I do go the route of creating my own cats, will it be approved by the DMV? Or just gut the cat... I wish I could...but I do not want the hassle of putting in a new cat when it is time for inspection. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 15, 2012 Mega Users Share Posted July 15, 2012 True. You'd get a diagnostic code from the cats not working and fail the test. All they care about is that you don't have any codes. They will not do a sniff test or visual on your car unless rules have changed in the last year. Link to comment Share on other sites More sharing options...
Kodax Posted July 15, 2012 Author Share Posted July 15, 2012 True. You'd get a diagnostic code from the cats not working and fail the test. All they care about is that you don't have any codes. They will not do a sniff test or visual on your car unless rules have changed in the last year. Do you know any reputable shops that could handle making a cat without throwing off the codes? I wouldn't mind paying a bit more for a good product. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 15, 2012 Mega Users Share Posted July 15, 2012 I don't know of any, but you have 3 cats to replace, so it can get expensive. Now that I think about it, I don't think it will trigger a code if you gutted them. It doesn't on the lgt and it's a similar setup in that the rear o2 sensor is directly behind a cat. It's the cat with an egt sensor in it that triggers codes and your car doesn't have an egt sensor AFAIK. Link to comment Share on other sites More sharing options...
Kodax Posted July 15, 2012 Author Share Posted July 15, 2012 I don't know of any, but you have 3 cats to replace, so it can get expensive. Now that I think about it, I don't think it will trigger a code if you gutted them. It doesn't on the lgt and it's a similar setup in that the rear o2 sensor is directly behind a cat. It's the cat with an egt sensor in it that triggers codes and your car doesn't have an egt sensor AFAIK. Sorry form my noobness but what is egt? Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 15, 2012 Mega Users Share Posted July 15, 2012 exhaust gas temp sensor. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 16, 2012 Share Posted July 16, 2012 Do you have any ball park range for the cat? Also, if I do go the route of creating my own cats, will it be approved by the DMV? I wish I could...but I do not want the hassle of putting in a new cat when it is time for inspection. The cats themselves vary if you stick with double dipped ceramic cats you are looking at btwn $75 and $100 per cat then labor to fab them into a cat-pipe unit or CBE. I would not replace all three with HFC variants instead I would replace one cat with a large HFC unit like a MagnaFlow 41000 series. The 41000 is what I ran on my previous setup with no CELs. Dont worry about the DMV simply replace your custom cat section with the stock prior to inspection. Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 16, 2012 Mega Users Share Posted July 16, 2012 Anyone know for sure whether there would even be a cel from it? If not, there's no need for anything inspection related. There is no "inspection". It's just an obd2 scan for codes. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 16, 2012 Share Posted July 16, 2012 I don't know of any, but you have 3 cats to replace, so it can get expensive. Now that I think about it, I don't think it will trigger a code if you gutted them. It doesn't on the lgt and it's a similar setup in that the rear o2 sensor is directly behind a cat. It's the cat with an egt sensor in it that triggers codes and your car doesn't have an egt sensor AFAIK. Gut the cats it will throw a P0420 code for sure. On the EZ30R you have too many sensors to try and trick so you should only focus on making the downstream o2 sensor happy. A metallic cat wont suffice, ceramic is the way. I wouldnt touch anything upstream of the the most rearward cat (the one upstream from the rear o2 sensor) Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 16, 2012 Mega Users Share Posted July 16, 2012 Then only the 3rd cat can be messed with unless they make it so you can swap in the stock cats. There are 2 downstream o2 sensors. Link to comment Share on other sites More sharing options...
Kodax Posted July 17, 2012 Author Share Posted July 17, 2012 The cats themselves vary if you stick with double dipped ceramic cats you are looking at btwn $75 and $100 per cat then labor to fab them into a cat-pipe unit or CBE. I would not replace all three with HFC variants instead I would replace one cat with a large HFC unit like a MagnaFlow 41000 series. The 41000 is what I ran on my previous setup with no CELs. Dont worry about the DMV simply replace your custom cat section with the stock prior to inspection. Thanks for the insight. So you are saying that I should just replace one of the HFC unit and leave the other 2 stock? I did a bit of digging about MagnaFlow 41000, it seem to be not legal for street use. This is getting more complicated than I expected. Any recommendation for cat that is legal for street use? Like I said I won't mind paying more. If this is getting way too complicated, I am going to ditch the idea of changing out my cats and just leave it stock while I install the new raptor H6 Headers. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 17, 2012 Share Posted July 17, 2012 When looking around the aftermarket world everything will state "race use or off-road use" to circumvent the various regulations. The 41000 is specifically made for OBII applications as I used that with no issues on a previous setup. Any recommendation for cat that is legal for street use? Like I said I won't mind paying more. If this is getting way too complicated, I am going to ditch the idea of changing out my cats and just leave it stock while I install the new raptor H6 Headers. This^ Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 17, 2012 Mega Users Share Posted July 17, 2012 If your ecu has been somewhat defined, disabling the p420 code would be easy. Might be worth a look into. That would get you through inspection easily. Link to comment Share on other sites More sharing options...
