Did it start before? When was the last time it started? Does the starter turn over? Is it getting fuel (bad fuel pump)? Did you take off the timing covers and check if the timing is correct? Did you check the battery and negative ground?
The fuel pump has a ground, check that too. Post a pic of your touring wagon.
Well if you're not good at replacing parts yourself
you need to hook them up with a new crank pulley,
woodruff key and that gear that goes behind the
crank pulley. I always called it a timing gear. Either
way, if they dont replace that crap when they do
the timing the crank pulley's just gonna wobble again.
A TD04 and 06-07 WRX tmic, coffee can mod, de snorkus, air intake, bigger wheels, EJ20G rob tuned ecu, 20G heads, STi suspension, projector retrofit, 6MT STi tranny, fmic, STi control arms, custom exhaust, etc. New sway bars, etc. Lol. The sky's the limit. Subarus are like legos. Check out legacy central for some good info. http://bbs.legacycentral.org/index.php
