KiNGKAOS Posted July 13, 2012 Share Posted July 13, 2012 So I've been readin' on here for about 2hrs on this issue. My 98 legacy L has a slight knock when I start it then goes away within a few minutes of running. What I've read n "understand" is: That as long as the "knock" goes away after warmin' up. That that is fine n will continue to be fine miles n miles to come!?! On a different note I'm throwin' a P0325(knock sensor) code. I've ordered a new one off of ebay it should be here next week sometime. My question with that is: After I replace the knock sensor n with my start-up "knock". Will my car be throwin' the P0325 code everytime I start my car, cuz it'll detect the "knock"!?! Thanx Link to comment Share on other sites More sharing options...
johnegg Posted July 13, 2012 Share Posted July 13, 2012 if the knock is piston slap there is a possibility that the knock sensor will pick it up, but i don't think it is common. very rare. but if it does, you can relocate the k-sensor to a less sensitive position. it would be nice to ID the knock you are hearing, just so you know. Link to comment Share on other sites More sharing options...
KiNGKAOS Posted July 13, 2012 Author Share Posted July 13, 2012 if the knock is piston slap there is a possibility that the knock sensor will pick it up, but i don't think it is common. very rare. but if it does, you can relocate the k-sensor to a less sensitive position. it would be nice to ID the knock you are hearing, just so you know. I'm not familiar with subaru's but I know a thing or 2 about cars.. As far as I can tell n hear. It sounds like a faint/not that loud "solid metal knock".. Not like lifter noise I know that cuz my Integra needs a valve adjustment done. The 2 sounds from each car are dif. sounding.. I hope that helps!?! Link to comment Share on other sites More sharing options...
KiNGKAOS Posted July 13, 2012 Author Share Posted July 13, 2012 Oh, I forgot 2 mention, that the "knock/sound" I hear isn't on "every start-up"... just when it's "cold"/1st start of the day.. Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 14, 2012 Share Posted July 14, 2012 Can you take a video of it? Link to comment Share on other sites More sharing options...
KiNGKAOS Posted July 14, 2012 Author Share Posted July 14, 2012 Can you take a video of it? Maybe with my cell phone... Or if I can find my digicam.. I can see what I can do. Link to comment Share on other sites More sharing options...
skibob6 Posted July 17, 2012 Share Posted July 17, 2012 It may just be the main rod journal farthest from the oil pump not being lubricated yet, i would try using Lucas oil stabilizer and seeing if it makes any difference Link to comment Share on other sites More sharing options...
SBT Posted July 17, 2012 Share Posted July 17, 2012 You sure it's not the hydraulic lift actuators? Had this on my Legacy L 2.2 and a couple were failing...so it had a louder metallic tap when first starting until it warmed up - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
KiNGKAOS Posted July 17, 2012 Author Share Posted July 17, 2012 I'm not quite sure what it is. I'm still workin' on gettin' a video of it. Link to comment Share on other sites More sharing options...
johnegg Posted July 17, 2012 Share Posted July 17, 2012 the 98 ej22 did not have hydraulic lash adjusters. Link to comment Share on other sites More sharing options...
SBT Posted July 17, 2012 Share Posted July 17, 2012 Sorry - mine was a 99 post April 99 version. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
