I Donated broknindarkagain Posted July 13, 2012 I Donated Share Posted July 13, 2012 Get one of those electric turbos. No turbo lag with them! -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 13, 2012 Share Posted July 13, 2012 A 20g+fmic may get you 350whp, but nowhere close to 400 on pump. If you truly want closer to 400awhp you should be looking at the ATP GT3071/GT3076, ATP GTX3071/GTX3076, Blouch Dom 1.5/2.5/3XT-R, FP HtaGreen etc. Oh, and LOTS of supporting mods for turbos in that range. Link to comment Share on other sites More sharing options...
MasAyinde Posted July 13, 2012 Share Posted July 13, 2012 From where the air enters the car to where it exits, you will need: Big MAF Turbo inlet Turbo listed above FMIC At least 850CC injectors DW65c or Walbro 255lph pump TGV deletes (optional but recommended) Turbo-back exhaust Don't forget a good tune. The higher your whp, the more likely shit will spontaneously blow up during a pull if your tune isn't good. Link to comment Share on other sites More sharing options...
05 LegacyGT Posted July 13, 2012 Share Posted July 13, 2012 Don't forget a catless uppipe. You don't want the cat in your stock UP destroying that brand new turbo. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted July 13, 2012 Share Posted July 13, 2012 Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted July 13, 2012 Share Posted July 13, 2012 1000cc's are excessive for 350-400whp, 840/850's should be plenty adequate. I'm running 305whp with 840's and only hitting about 70% on the duty cycle, I'd be surprised if anyone with 840/850 injectors is getting above 90% in the 350-400whp range. Link to comment Share on other sites More sharing options...
MasAyinde Posted July 13, 2012 Share Posted July 13, 2012 http://forums.nasioc.com/forums/showthread.php?t=1393580 Link to comment Share on other sites More sharing options...
rockle3 Posted July 13, 2012 Share Posted July 13, 2012 i say at least a gt35 if you really want 400 awhp. I made a hair above 300 with a 18gxt..... Link to comment Share on other sites More sharing options...
whitetiger Posted July 13, 2012 Share Posted July 13, 2012 The 06 Spec.B has the 5-Speed right? Forgive my ignorance, but will the transmission need more work than just a clutch to hold 400 WHP? its not the whp that matters, but rather the wtq and when in the RPM band it occurs. if e85 is being used, then large tq numbers could be made relatively low inthe rpm bad and that could break a stock trans if driven hard. 400whp usually requires larger turbos which are laggy compared to smaller turbos intended for 325-350whp, so tq wont occur so low as to endanger the trans as much. if most of the driving is dont at highway speeds and not alot of drag racing or hole shots are done, then the 5mt should be ok. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 13, 2012 Share Posted July 13, 2012 i say at least a gt35 if you really want 400 awhp. I made a hair above 300 with a 18gxt..... Are you serious? A fully supported gt3076r will easily overshoot OP's goals. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted July 13, 2012 Share Posted July 13, 2012 subscribed [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 13, 2012 I Donated Share Posted July 13, 2012 Are you serious? A fully supported gt3076r will easily overshoot OP's goals. I made just shy of 400 to the wheel with my EJ20R & gT3076R -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
turbodog Posted July 13, 2012 Share Posted July 13, 2012 Ditto. Link to comment Share on other sites More sharing options...
turbodog Posted July 13, 2012 Share Posted July 13, 2012 OK so I want to build an approximately 400awhp on pump gas spec b but I can't decide on the Turbo. I've been searching on here and everyone sseems to argue between fp green and blouch. But no one states clear reasons why. I just want to hit 400 HP with minimum lag if possible. Help is appreciated. If you can just state the reasons and why a Turbo design is better than the other that would be great. I don't this thread becoming another 100 page argument thread. Thanks everyone Two things you absolutely need: a turbo with a compressor side capable of at least 50 lb/min, and alcohol injection. Anything short that is a non-starter. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 13, 2012 I Donated Share Posted July 13, 2012 Two things you absolutely need: a turbo with a compressor side capable of at least 50 lb/min, and alcohol injection. Anything short that is a non-starter. Oh God, look who has shown up with their infinite automotive wisdom. :lol::lol: -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
TheOneDoubleN Posted July 13, 2012 Share Posted July 13, 2012 Two things you absolutely need: a turbo with a compressor side capable of at least 50 lb/min, and alcohol injection. Anything short that is a non-starter. Please kindly STFU you have no good knowledge to impart to anyone on these forums. Link to comment Share on other sites More sharing options...
MasAyinde Posted July 13, 2012 Share Posted July 13, 2012 wow turbodog please do not even bother to comment in this thread. Go buy another car already. You don't need alcohol injection AT ALL to hit 400whp. Just look at guys on nasioc that have hit 400whp and look at how many of them don't have meth injection. Now STFU you are wrong. Link to comment Share on other sites More sharing options...
turbodog Posted July 13, 2012 Share Posted July 13, 2012 wow turbodog please do not even bother to comment in this thread. Go buy another car already. You don't need alcohol injection AT ALL to hit 400whp. Just look at guys on nasioc that have hit 400whp and look at how many of them don't have meth injection. Now STFU you are wrong. Really. Have you made anywhere near 400whp? On pump gas? On a stock longblock? Guess who has. I can personally assure you that it is a very bad idea to try 200 chp/liter without some sort of octane enhancement, be it either WI, e85, torco, race gas, etc. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 13, 2012 Share Posted July 13, 2012 Two things you absolutely need: a turbo with a compressor side capable of at least 50 lb/min, and alcohol injection. Anything short that is a non-starter. Can you tell us why you don't absolutely need a tune? lol Link to comment Share on other sites More sharing options...
turbodog Posted July 13, 2012 Share Posted July 13, 2012 Can you tell us why you don't absolutely need a tune? You need a tune, and many other supporting mods. obviously. Link to comment Share on other sites More sharing options...
turbodog Posted July 13, 2012 Share Posted July 13, 2012 wow turbodog please do not even bother to comment in this thread. Go buy another car already. You don't need alcohol injection AT ALL to hit 400whp. Just look at guys on nasioc that have hit 400whp and look at how many of them don't have meth injection. Now STFU you are wrong. http://forums.nasioc.com/forums/showthread.php?t=2315127 Link to comment Share on other sites More sharing options...
dr_sharp Posted July 13, 2012 Share Posted July 13, 2012 You need a tune, and many other supporting mods. obviously. Can you do me a favor and remove me from your ignore list? And also, change your avatar picture http://www.partyvibe.com/forums/attachments/growing-cannabis-making-hash/81915d1339459739-help-my-baby-grow-up-goonies-2-movie.jpg lol Link to comment Share on other sites More sharing options...
MasAyinde Posted July 13, 2012 Share Posted July 13, 2012 Really. Have you made anywhere near 400whp? On pump gas? On a stock longblock? Guess who has. I can personally assure you that it is a very bad idea to try 200 chp/liter without some sort of octane enhancement, be it either WI, e85, torco, race gas, etc. He specified 400whp on pump gas. Now we're here telling him which turbo to use and which supporting mods to get as a bare minimum. Sure, he can rebuild his entire block and drop $4000 on internals, but to hit 400whp, you don't NEED alcohol or anything more than pump gas. Link to comment Share on other sites More sharing options...
turbodog Posted July 14, 2012 Share Posted July 14, 2012 He specified 400whp on pump gas. Now we're here telling him which turbo to use and which supporting mods to get as a bare minimum. Sure, he can rebuild his entire block and drop $4000 on internals, but to hit 400whp, you don't NEED alcohol or anything more than pump gas. Perhaps you don't NEED it. You could touch 400 whp, but it would not be at all safe or reliable. You do absolutely need a turbo comfortably capable of 50 lb/min, that's the air flow for 500 chp or roughly 400 whp. This is not negotiable unless you're willing to run leaded race gas on an optimized setup with a built motor, to pull more power out of reduced air flow. Given that pump gas is a requirement, I state that WI is the only way to get the octane enhancement that will allow you reasonably make that kind of power on a stock longblock. You could run torco additive, but I don't consider that pump gas. If you actually look into it and sweat the details, you'll find that very few (or none) are actually making 400 whp on the stock longblock with 93 octane w/o WI - because most people know better. Please point to examples that prove me wrong. http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/199014-cheapest-way-go-400whp.html Link to comment Share on other sites More sharing options...
MasAyinde Posted July 14, 2012 Share Posted July 14, 2012 Because these people want to run around with 400whp (semi) reliably. If OP really wants to stick with stock gas, then by reading up he'll realize that he'll be prone to detonation. He can and will get to 400whp with pump gas and no alky, but he'll be flirting with destroying his motor. Link to comment Share on other sites More sharing options...
