claymore_6r Posted July 10, 2012 Share Posted July 10, 2012 Does anyone know what the solid triangle shape light on the tach is? It's keep appearing on and off as the car is running. Thanks in advance! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 10, 2012 Moderators Share Posted July 10, 2012 It's probably a shift light. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
NWSPECB Posted July 10, 2012 Share Posted July 10, 2012 It is. You are in I-Mode (assuming you have S-Drive) and it tells you when you should shift. Link to comment Share on other sites More sharing options...
Rusty9 Posted July 10, 2012 Share Posted July 10, 2012 I hate that light. It wants you to shift at any and all times you are over 2k rpm. even in 6th! maybe mines broken.... I think there is a way to turn it off. I believe i skimmed over it in the manual once. Link to comment Share on other sites More sharing options...
dr_sharp Posted July 10, 2012 Share Posted July 10, 2012 Someone shoudl hack that light to tell you when your tire pressure goes below 42psi lol Link to comment Share on other sites More sharing options...
NWSPECB Posted July 10, 2012 Share Posted July 10, 2012 Quit driving in I-mode then. Link to comment Share on other sites More sharing options...
NWSPECB Posted July 10, 2012 Share Posted July 10, 2012 Someone shoudl hack that light to tell you when your tire pressure goes below 42psi Why wouldn't you just hack the tpms light to do that Link to comment Share on other sites More sharing options...
claymore_6r Posted July 10, 2012 Author Share Posted July 10, 2012 Yeah I should've read the manual... SO the light comes on while using the "I" drive? Yeah the light on the TMPS sucks as well! LOL Thanks Fellas Link to comment Share on other sites More sharing options...
Nrw Posted July 10, 2012 Share Posted July 10, 2012 Why wouldn't you just hack the tpms light to do that Because he hacked the tpms light to stay off? Link to comment Share on other sites More sharing options...
NWSPECB Posted July 10, 2012 Share Posted July 10, 2012 Comes on when you are in I-mode (Intelligent mode). This is one reason I leave my car in S-mode. Link to comment Share on other sites More sharing options...
NWSPECB Posted July 10, 2012 Share Posted July 10, 2012 Because he hacked the tpms light to stay off? That's what I need to do Link to comment Share on other sites More sharing options...
claymore_6r Posted July 11, 2012 Author Share Posted July 11, 2012 That's what I need to do also...Where could I find the info to disconnect the TMPS? Link to comment Share on other sites More sharing options...
dr_sharp Posted July 11, 2012 Share Posted July 11, 2012 My job here is done. lol Link to comment Share on other sites More sharing options...
NWSPECB Posted July 11, 2012 Share Posted July 11, 2012 ^ That's what I need to do also...Where could I find the info to disconnect the TMPS? pm turbodog. He should be able to answer your question. He know's a little of everything, or so I hear. Link to comment Share on other sites More sharing options...
