travgag Posted July 9, 2012 Share Posted July 9, 2012 S0 my 97 legacy outback, with a 2.5 of course, had symptoms of blown headgaskets, (over pressurising of the collant system) The car has 247 000 k and these arent stock head gaskets right ? and do they look blown ? just wondering Also the car had dexcool in it, that made me think that the head gaskets had been done before and they changed the coolant type, should I stick with dexcool ? or swap it, ive heard bad things about deathcool lol thanks http://www.valleyeastringette.com/head4.jpg http://legacygt.com/forums/www.valleyeastringette.com/head4.jpg http://legacygt.com/forums/S0%20my%2097%20legacy%20outback,%20with%20a%202.5%20of%20course,%20had%20symptoms%20of%20blown%20headgaskets,%20%28over%20pressurising%20of%20the%20collant%20system%29%20%20The%20car%20has%20247%20000%20and%20these%20arent%20stock%20head%20gaskets%20right%20?%20and%20do%20they%20look%20blown%20?%20just%20wondering%20%20Also%20the%20car%20had%20dexcool%20in%20it,%20that%20made%20me%20think%20that%20the%20head%20gaskets%20had%20been%20done%20before%20and%20they%20changed%20the%20coolant%20type,%20should%20I%20stick%20with%20dexcool%20?%20or%20swap%20it,%20ive%20heard%20bad%20things%20about%20deathcool%20lol%20%20thanks http://www.valleyeastringette.com/head3.jpg http://www.valleyeastringette.com/head2.jpg http://www.valleyeastringette.com/head1.jpg Link to comment Share on other sites More sharing options...
SpecBamf41 Posted July 10, 2012 Share Posted July 10, 2012 are they mutilayer steel or graphite gaskets? BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 10, 2012 I Donated Share Posted July 10, 2012 Whoever put dexcool in a Subaru is a fking idiot. Flush the hell out of it. Get as much out as you can and use extended life coolant. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
travgag Posted July 10, 2012 Author Share Posted July 10, 2012 yea there's like three or four layers of steel, ive seen a stock gasket and its not the same, yea talk about screwing up with dexcool, i think il try to flush it out and put the green stuff, or are you talking about subaru specific coolant ? Link to comment Share on other sites More sharing options...
JJay03 Posted July 10, 2012 Share Posted July 10, 2012 Thats exactly how mine looked. Make sure your head and block surfaces are flat too. http://i99.photobucket.com/albums/l285/spdfrk1990/Legacy/Legacy053.jpg Link to comment Share on other sites More sharing options...
travgag Posted July 10, 2012 Author Share Posted July 10, 2012 yea same look, yea the heads are at the machine shop getting shaved, Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 11, 2012 Share Posted July 11, 2012 Have them do a valve job at the same time so your clearances are to spec, right? Link to comment Share on other sites More sharing options...
JJay03 Posted July 11, 2012 Share Posted July 11, 2012 I would get a valve job done I said no then checked my clearances and they were not in spec so now im ordering shims. Link to comment Share on other sites More sharing options...
travgag Posted July 12, 2012 Author Share Posted July 12, 2012 it had good compression, so il check spec on them Link to comment Share on other sites More sharing options...
JJay03 Posted July 13, 2012 Share Posted July 13, 2012 Spec is .20mm for the intake and .25 for the exhaust. Link to comment Share on other sites More sharing options...
GTTuner Posted July 13, 2012 Share Posted July 13, 2012 Watch the surface roughness when you have them machined. MLS gaskets need a nice smooth surface. Link to comment Share on other sites More sharing options...
JJay03 Posted July 13, 2012 Share Posted July 13, 2012 Mine were pretty rough after resurfacing I sanded them with some 600 on a block after hopefully it was enough. I did use new head bolts also. Link to comment Share on other sites More sharing options...
