TrueWhiteBoy Posted July 9, 2012 Share Posted July 9, 2012 Recommendation for work done. I'm having a shop do my 120K and replace the timing belt/water pump. I was quoted $465 for the belt/pump assembly: T-belt tensioner $100.00 Timing belt $80.00 Cogged roller $30.00 Small roller $35.00 2 smooth rollers $70.00 Water pump $120.00 Thermostat assembly $30 (+ tax) and essentially I was wondering if I sourced the parts myself if I could save some money. What do you guys think? Unfortunately I don't know much about the manufacturers to know what kits are good and which aren't. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 10, 2012 Share Posted July 10, 2012 Read the timing belt threads, all the info is there. http://legacygt.com/forums/showthread.php/my-timing-belt-replacement-182537.html http://legacygt.com/forums/showthread.php/timing-belt-replacement-2-5t-106809.html I bought my Gates kit on here for under $300, it comes with everything, retail is about $350 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
