dr_sharp Posted August 1, 2012 Share Posted August 1, 2012 Ya but you were just trolling. I was swallowing. lol Link to comment Share on other sites More sharing options...
bmx045 Posted August 1, 2012 Share Posted August 1, 2012 Hey, I help people on here. I do enjoy calling people out too, but it's trial by fire. Internet is no joke. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 1, 2012 Share Posted August 1, 2012 ^True but you make me laugh at least once per day. I don't even need help once per day from anyone. hey I did my part of the LAFFload!^^ Fixed:) Link to comment Share on other sites More sharing options...
spc2125 Posted August 2, 2012 Author Share Posted August 2, 2012 Getting gaskets for my used indivia uppipe http://legacygt.com/forums/showthread.php/fs-pa-gaskets-galore-189270.html?t=189270&highlight=gaskets+galore Should I buy the Agency Power Exhaust Manifold to Uppipe Gasket $7.00 pics 10 & 11 Or what about buying oem gaskets? Or should i buy something like this http://www.fredbeansparts.com/grimmspeed-header-to-uppipe-2x-thick-gasket.html and this http://www.fredbeansparts.com/grimmspeed-up-pipe-to-turbo-gasket.html tell me what you think Link to comment Share on other sites More sharing options...
bmx045 Posted August 2, 2012 Share Posted August 2, 2012 oem. or grimmspeed. thats the only shite i'd use. Link to comment Share on other sites More sharing options...
dr_sharp Posted August 2, 2012 Share Posted August 2, 2012 grimmspeed double thick for when you need that extra leak protection. lol Link to comment Share on other sites More sharing options...
bmx045 Posted August 2, 2012 Share Posted August 2, 2012 if you need an extra thick, there's a problem. two exhaust mating surfaces should be flat, if it isnt, fix that, if it is, a normal thickness gasket will work. Link to comment Share on other sites More sharing options...
dr_sharp Posted August 2, 2012 Share Posted August 2, 2012 this is true for UP. My doublethick is on the DP to exhaust connection... them bitches aint flat lol Link to comment Share on other sites More sharing options...
bmx045 Posted August 2, 2012 Share Posted August 2, 2012 i had that issue and the fix was the appropriate gasket, an adapter. boom, in there like swimwear, didn't even need a gasket after, but i did use rtv... Link to comment Share on other sites More sharing options...
spc2125 Posted August 4, 2012 Author Share Posted August 4, 2012 Alrite well i think im changing my mind. I found a magnaflow cat back for $300. So im going to get it and also the uppipe for $80. Then im going to install the catback. Wait for my bday (mid august) and then install my uppipe and downpipe and then get a tune. When time for school comes around, Ill be stage 2 in my Spec B with my magnaflow cbe ! Link to comment Share on other sites More sharing options...
Nrw Posted August 4, 2012 Share Posted August 4, 2012 Magnaflow makes a nice exhaust. Used to have one on mine Link to comment Share on other sites More sharing options...
InnocentGuns Posted August 4, 2012 Share Posted August 4, 2012 i had that issue and the fix was the appropriate gasket, an adapter. boom, in there like swimwear, didn't even need a gasket after, but i did use rtv... rtv on exhaust flanges? bet that didnt last long. Link to comment Share on other sites More sharing options...
bmx045 Posted August 4, 2012 Share Posted August 4, 2012 It worked fine. Its called gasket maker its made for high temps....IE valve covers and heads Link to comment Share on other sites More sharing options...
Nrw Posted August 4, 2012 Share Posted August 4, 2012 When I was cleaning up the SPTV2.0 that's now on my car, used to be BMX's, the flanges still had red rtv on them. Though these were further back. Link to comment Share on other sites More sharing options...
dr_sharp Posted August 5, 2012 Share Posted August 5, 2012 how does the spt2.0 compare to the magnaflow? lol Link to comment Share on other sites More sharing options...
Nrw Posted August 5, 2012 Share Posted August 5, 2012 A lot quieter, so quiet my poly bushings drive me nuts lol (I need to regrease everything). It sits lower but I've only scrapped it once, I'm on h-techs/konis. I like the look better with it mirror polish. Link to comment Share on other sites More sharing options...
dr_sharp Posted August 5, 2012 Share Posted August 5, 2012 It worked fine. Its called gasket maker its made for high temps....IE valve covers and heads How do you apply it? Smear it all over the main gasket before you mate the pipes or apply it around the perimeter after the fact? lol Link to comment Share on other sites More sharing options...
bmx045 Posted August 5, 2012 Share Posted August 5, 2012 Yea. Just put some on both sides of the gasket and there will be no more leaks Link to comment Share on other sites More sharing options...
spc2125 Posted August 9, 2012 Author Share Posted August 9, 2012 Well heres my story. I bought a 06 spec b that i thought was unmodified. The turbo blew around 72k miles and a new one was put in and also a used motor with 2k less miles. I bought it for a steal of a price so im still ahead on it. But I was installing the CNT downpipe and found out a lot about my car. First of all, the turbo doesnt appear to look like the VF40. I cant make out any numbers on it so it remains a mystery for now. Anyways, on top of the turbo where the intercooler mounts, there is another (3rd) hole drilled in (closest to the windshield). The bolt goes in but there is a nut that was put under the bolt to hold it in place. The other bolt is fine. Its an aftermarket Perrin TMIC, but i dont know why there would be fitment issues with it. Next, when taking off the bolts from the downpipe to the turbo, the one of the top on the passenger side, looks to have been screwed in sideways because it has a very hard time going in and out and doesnt come out through the bolt hole like its supposed to. Then when I was taking off the spring bolts where the dp meets the catback, the bolts broke. I ended up just using some bolt without the spring. However, there is an exhaust leak there. I used the gasket that came with the dp, but the reviews said this was a common problem. Which to be honest I dont mind because I LOVE the rumble, i just want it to be safe and not fall off. Lastly, the tranny mount where the dp is suppose to hang on doesnt match up right so I dont know if I should just bend that piece of metal (tranny mount) so I dont have to hear the rattling of it. I still have the up pipe to install and want to make sure everything is safe before I do it. Any ideas what I should do. Everything works, so I theres a part of me that says not to fix anything, but i would want to see what my options are. Im on a limited budget so spending $600 to make everything right is not an option right now. Link to comment Share on other sites More sharing options...
bmx045 Posted August 9, 2012 Share Posted August 9, 2012 pics would help, of the turbo....and tmic connection. we can identify. Link to comment Share on other sites More sharing options...
spc2125 Posted August 9, 2012 Author Share Posted August 9, 2012 pics would help, of the turbo....and tmic connection. we can identify. I know it would help, maybe soon I will take it off again, but boy was it a pain in the ass to take off and put on when it should have been soo easy. Other real quick question, why do people remove the top of the DP to uninstall the up pipe? Are the top of the uppipe bolts right under neath it? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted August 9, 2012 Share Posted August 9, 2012 300+ for sure! /stealth troll Link to comment Share on other sites More sharing options...
Max Capacity Posted August 9, 2012 Share Posted August 9, 2012 My DP is not attached to the tranny either, no problem yet. The turbo sits on top of the up pipe. http://i185.photobucket.com/albums/x40/92Si/DSCN4783.jpg Hint, notice my turbo is bolted on, no studs. It's much easier. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
spc2125 Posted August 10, 2012 Author Share Posted August 10, 2012 300+ for sure! /stealth troll But what is there to fix? Everything works ya know? I just dont want to try and fix something and end up breaking something and having to spend MORE money Link to comment Share on other sites More sharing options...
aggmcmuffin Posted August 10, 2012 Share Posted August 10, 2012 What is there to fix? Maybe I'm missing something since I wasn't there for the whole instal. As far as I can tell, your car isn't going to blow up. If its not broken... Don't "fix" it. Link to comment Share on other sites More sharing options...
