StoplightAssassin Posted July 6, 2012 Share Posted July 6, 2012 This is probably the easiest thing you'll ever make. This is such a great tool for the track guys and autocrossers. What you need: 2 ~1.5in bolts 4 washers 2 wing nuts 2 regular nuts (or rounded endcaps if you prefer) 1 36in piece metal stock with 90 degree bend and pre slotted/drilled (you would probably be ok with a 24in piece as long as you don't have a donk) 1 digital level. I have this one available at Home Depot for $40: http://www.homedepot.com/buy/tools-hardware/hand-tools/husky/9-in-digital-level-115526.html Here's a Craftsmen model for under $30: http://www.sears.com/craftsman-digital-torpedo-level/p-00948295000P?prdNo=1&blockNo=1&blockType=G1 http://legacygt.com/forums/attachment.php?attachmentid=121909&stc=1&d=1341602443 Put it all together. For the slow people, here's how to assemble the bolts. The level I used and the Craftsmen one I linked are both magnetic. Note...nut should be flush with tip of the bolt for measurement. It gives it a little scratch protection. http://legacygt.com/forums/attachment.php?attachmentid=121911&stc=1&d=1341602443 Take a measurement. The car should be on a flat surface. If the car is not level, your results will be off. Finding a perfectly level surface to park your car on could very well be the most challenging aspect of this. Measure from the part of the lip closest to the ground to the part of the lip closest to the sky. Hopefully your lip isn't bent or rashed too badly. http://legacygt.com/forums/attachment.php?attachmentid=121910&stc=1&d=1341602443 Boom. -2.2. Dead on balls accurate. It's an industry term. Link to comment Share on other sites More sharing options...
Gire Posted July 6, 2012 Share Posted July 6, 2012 moved! And nice thread! Link to comment Share on other sites More sharing options...
