yamaha125 Posted July 6, 2012 Share Posted July 6, 2012 there is a clunking noise when i turn and when my suspension compresses i was wondering if anyone else has had this problem and if you fixed it. here are my ideas: bad control arm bushings bad u joints on the steering shafts Link to comment Share on other sites More sharing options...
Stang70Fastback Posted July 6, 2012 Share Posted July 6, 2012 Have you looked at the swaybar endlinks? The bushings on those like to wear out. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted July 6, 2012 I Donated Share Posted July 6, 2012 Swaybar end links -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
brokentv Posted July 7, 2012 Share Posted July 7, 2012 what would be the second thing to check if you have new sway bar end links on.I also have a rattle/clunk when I hit descent sized bumps my guess is left front strut. Link to comment Share on other sites More sharing options...
monkeyposeur Posted July 7, 2012 Share Posted July 7, 2012 A bad ball joint was giving me a clunking sound when I hit potholes and bumps. Check for that too. Yank on your wheel and see if there is a lot of play. Link to comment Share on other sites More sharing options...
NewLegGT67 Posted July 7, 2012 Share Posted July 7, 2012 Subscribed - I also have a clunking sound in the trunk when I hit bumps. I'm probably the only person that has Wu-Tang Clan and Paul McCartney on their mp3. Link to comment Share on other sites More sharing options...
subikid90 Posted July 7, 2012 Share Posted July 7, 2012 Check you sway bar mount under the trunk pan, I broke mine off a few months ago. I have seen the bushings tear apart also leaving room for the sway bar to clunk. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
