ilya124 Posted July 4, 2012 Share Posted July 4, 2012 I found an annoying problem in my legacy. It seems that the lumber support adjuster of the drivers seat is rubbing against the center console and making a squeak. I tried putting a paper towel in between and it worked until you open the console. The paper towel doesn't stay in place. Any suggestions? Thanks. Link to comment Share on other sites More sharing options...
BAC5.2 Posted July 4, 2012 Share Posted July 4, 2012 Move your seat back, and don't gangster lean it? Take a picture. My lumbar lever doesn't even come REMOTELY close to the console. If it does bother you, just grab some sand paper and file it down a bit. Then finish it off with some extra-fine-grit so it's not so noticeable. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
ilya124 Posted July 4, 2012 Author Share Posted July 4, 2012 It's strange it's not rubbing all the time. Usually when I go in a corner and the seat leans to the right, it rubs. Or if I go over a bump Link to comment Share on other sites More sharing options...
