ScoobySnax Posted July 3, 2012 Share Posted July 3, 2012 My drivers window switch is a little tough and sometimes tries to stick in the up position and I almost fried it the other day when I didnt notice. Any ideas on what to do? Thanks in advance. Link to comment Share on other sites More sharing options...
meier motor sports Posted July 3, 2012 Share Posted July 3, 2012 My drivers window switch is a little tough and sometimes tries to stick in the up position and I almost fried it the other day when I didnt notice. Any ideas on what to do? Thanks in advance. same here. pretty sure i didnt spill pop or anything on the drivers door:lol: Link to comment Share on other sites More sharing options...
Max Capacity Posted July 5, 2012 Share Posted July 5, 2012 Mine did the same thing years back before the dealer replaced the whole control under warranty after it stopped working. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lieutenantcolumbo Posted July 5, 2012 Share Posted July 5, 2012 http://legacygt.com/forums/showthread.php/sticky-power-window-switch-142360.html?t=142360&highlight=Window+switch Link to comment Share on other sites More sharing options...
Leviman Posted July 5, 2012 Share Posted July 5, 2012 A common problem. All that happens is that the grease in there wears out and stops lubricating it. Don't spray contact cleaner in there whatever you do, as that will eat all the grease and make it even worse. Link to comment Share on other sites More sharing options...
OneJay Posted July 5, 2012 Share Posted July 5, 2012 Mine is a little sticky too. It takes a bit of effort to pull or push it up or down, but it works fine otherwise. Link to comment Share on other sites More sharing options...
Joon525 Posted July 5, 2012 Share Posted July 5, 2012 A common problem. All that happens is that the grease in there wears out and stops lubricating it. Don't spray contact cleaner in there whatever you do, as that will eat all the grease and make it even worse. Some people would disagree about the lubricant part... http://legacygt.com/forums/showpost.php?p=3038707&postcount=65 Here's the best solution: http://legacygt.com/forums/showpost.php?p=669054&postcount=10 (pictures from the same thread) http://legacygt.com/forums/showthread.php/drivers-window-switch-died-today-38349p5.html?highlight=Driver%27s+window+switch Link to comment Share on other sites More sharing options...
ScoobySnax Posted July 6, 2012 Author Share Posted July 6, 2012 didnt think about the warranty lol. I guess I bought it for a reason so I might as well use it Link to comment Share on other sites More sharing options...
