nismohrdbody Posted July 3, 2012 Share Posted July 3, 2012 do yall know what the green two wire connector is that is located on the passanger floor board , under the glove box? i was changing the cabin air filter and i noticed that it was unplugged. Link to comment Share on other sites More sharing options...
Dujo Posted July 3, 2012 Share Posted July 3, 2012 It is supposed to be unplugged. It is used as a physical control switch to put the ECU in a state where it can accept a new ROM loaded onto the computer. It's done as a plug so that there's no possible way you could accidentally bump a switch. I don't know if it has any other purpose. But you only connect them when you are flashing your ECU. You don't even connect them when logging. Leave 'em be. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 3, 2012 Share Posted July 3, 2012 Leave them unplugged, they are for reflashing the ECU. Do not plug them in, When you get the tuned then you'll connect them to reflash the map. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted July 3, 2012 Share Posted July 3, 2012 Their actual purpose and name are the "test mode" connectors. When connected, the ECU cycles every relay and switch in the car on and off. It's used to check vehicle components upon first delivery at the dealer. It just so happens that it also puts the ecu into a writable state. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
I Donated Too laff79 Posted July 3, 2012 I Donated Too Share Posted July 3, 2012 they power the flux capacitor, silly Link to comment Share on other sites More sharing options...
BeastLGT Posted July 3, 2012 Share Posted July 3, 2012 ^ what he said. lol Link to comment Share on other sites More sharing options...
lingling1337 Posted July 3, 2012 Share Posted July 3, 2012 ^haha ya lol Link to comment Share on other sites More sharing options...
nismohrdbody Posted July 4, 2012 Author Share Posted July 4, 2012 ok cool thanks guys Link to comment Share on other sites More sharing options...
jhawk222 Posted July 5, 2012 Share Posted July 5, 2012 do yall know what the green two wire connector is that is located on the passanger floor board , under the glove box? i was changing the cabin air filter and i noticed that it was unplugged. Did the discovery of the mysterious unplugged connectors freak you out??? Link to comment Share on other sites More sharing options...
Leviman Posted July 5, 2012 Share Posted July 5, 2012 It turns on spec b, right? Link to comment Share on other sites More sharing options...
alegend90 Posted July 5, 2012 Share Posted July 5, 2012 they power the flux capacitor, silly oh, must be a spec b if it has a flux. Link to comment Share on other sites More sharing options...
