Boston Motorsports Posted June 12, 2012 Share Posted June 12, 2012 Boston Motorsports is a direct dealer of Killer B Motorsport. Since we have received a ton of requests for their new Holy Header, we decided to offer a group buy to help everyone get the best header on the market at the best price!! We will keep this simple. First come first serve bases. ONLY 10 units available at this price level!! Don't miss your chance to SAVE BIG!! $1275 Shipped!! (Lower 48 States) Killer B Motorsport Holy Header http://www.killerbmotorsport.com/index_files/image1884.jpg Place Your Order Today!! As soon as we hit the 10th spot orders will be shipped out. 1. etl003 (Paid) 2. Ecks769 (Swain Tech Coating - Paid) 3. shadowpr (Swain Tech Coating - Payment Pending) 4. JarHarms (Swain Tech Coating - Paid) 5. 6. 7. 8. 9. 10. The Killer B Motorsport Holy Header was developed using state of the art CAD software & simulations to determine optimal design to increase power in the mid to high RPM range. Short as possible primaries with a single secondary significantly decrease header volume allowing exhaust gas pressure to build quickly. Symmetrical 4-1 design maintains high and consistent exhaust velocity as RPMs rise. You can expect faster spool up time compared to long primary/double secondary designs. A difference you will immediately notice in throttle response and the ability to hold more power higher into the revs. Features include: · Short Equal Length Primaries. The shortest possible length primaries you can have on an Equal Length header. Short means less header volume and quick spool up. · Symmetrical Primary Design. All primaries have a similar tube length AND bend geometry. This keeps the pulse velocities high and consistent compared to equal length headers with different (non-symmetrical) primary tubing geometry. · Smooth Mandrel Bends. All of the bends utilize a mandrel for smooth non-restrictive flow. Not only that, we use the largest bends possible at every location. It would be cheaper to use 2” bends everywhere, like others do, but that’s not going to give the best performance. · Thick Walled 321 Stainless Steel Construction for Long Life. 321 is alloyed with titanium, costs more, a lot more, but it’s the ideal material for high temperature turbocharged applications. Would 304 stainless work, yes, but the temperatures on our turbocharged cars can exceed the limits of 304 stainless enough to make them brittle and crack. 321 stainless steel has higher strength and toughness at elevated temperatures. It was developed by the aircraft industry specifically to address 304 stainless manifolds that were cracking. Killer B Motorsport is the only company that manufactures full 321 headers. · High Heat Retention. 321 stainless steel conducts less heat than 304 stainless steel. The short primaries and properly sized secondaries also pull less heat from the exhaust gasses increasing turbine efficiency. Large tubing headers expose the exhaust gasses to more surface area transmitting more heat and reducing exhaust energy. You can also ceramic coat or wrap our headers (and keep the warranty) without exceeding the temperature range like you can with 304 stainless. · V-Band Up-Pipe Connection. Why V-Band? Fast, easy, no gasket, no leaks, perfectly concentric alignment of tubes for no disruption of flow, what’s not to like! · Up-Pipe included. Of course it comes with an Up-Pipe! This header was designed as a complete system. Using other up-pipes would only compromise performance, and nobody wants that. · Weights only 17 pounds (vs. OEM weights 25 pounds) · Works with OEM EJ25 Oil Pans, and Killer B Motorsport Performance Aluminum Oil Pan! · Made in the USA and Killer B quality! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted June 14, 2012 Author Share Posted June 14, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted June 20, 2012 Author Share Posted June 20, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted June 24, 2012 Author Share Posted June 24, 2012 Keep 'em coming!! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted June 25, 2012 Author Share Posted June 25, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted June 26, 2012 Author Share Posted June 26, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted June 27, 2012 Author Share Posted June 27, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 10, 2012 Author Share Posted July 10, 2012 Keep 'em coming!! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 12, 2012 Author Share Posted July 12, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 13, 2012 Author Share Posted July 13, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 15, 2012 Author Share Posted July 15, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 16, 2012 Author Share Posted July 16, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 16, 2012 Author Share Posted July 16, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 18, 2012 Author Share Posted July 18, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 22, 2012 Author Share Posted July 22, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted July 23, 2012 Author Share Posted July 23, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted August 17, 2012 Author Share Posted August 17, 2012 All PM's replied, Happy Friday! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted August 19, 2012 Author Share Posted August 19, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted August 22, 2012 Author Share Posted August 22, 2012 All PM's replied! Link to comment Share on other sites More sharing options...
Boston Motorsports Posted August 24, 2012 Author Share Posted August 24, 2012 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
SCASEYS Posted January 11, 2013 Share Posted January 11, 2013 anyone have a review on these yet? I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
Boston Motorsports Posted January 12, 2013 Author Share Posted January 12, 2013 anyone have a review on these yet? http://www.killerbmotorsport.com/index_files/header.htm http://www.iwsti.com/forums/gr-exhaust/219298-killer-b-holy-header-arrived-coated-wrapping-progress.html Link to comment Share on other sites More sharing options...
Boston Motorsports Posted January 13, 2013 Author Share Posted January 13, 2013 All PM's replied, thanks for the orders! Link to comment Share on other sites More sharing options...
