rampage89312 Posted September 6, 2021 Share Posted September 6, 2021 I need the pin out one a ej 31711ag850 tcu please Link to comment Share on other sites More sharing options...
evil03mustang Posted November 12, 2021 Share Posted November 12, 2021 I was having brutally harsh 2-4/3-4 upshift when chopping the throttle at 60mph from a WOT pull. Previous owner had put a parts store engine oil filter where the genuine Subaru Tokyo-Roki AT fluid filter is supposed to go.. Seems to have taken care of the issue. Might be too good to be true tho.. kinda early to know for sure. Still needs a fluid and pan filter swap. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Smokey Posted December 2, 2021 Share Posted December 2, 2021 Hello, I have been trying to find a place to buy the hex mod 1 valve body for the automatic transmission of my 05 Lgt. I keep reading about it but cant find any place selling it. Please help!!! Link to comment Share on other sites More sharing options...
dwmccauley01 Posted December 16, 2021 Share Posted December 16, 2021 Hello, I have been trying to find a place to buy the hex mod 1 valve body for the automatic transmission of my 05 Lgt. I keep reading about it but cant find any place selling it. Please help!!!There's a Russian guy on ebay selling modded valvebodys for the 5eat. Not sure how good they are but I think read a member buying from them. Other than that you can buy the RE5R05A HD-2 kit and follow hexmods walk through or get a shop to put it in. Sent from my SM-G970U using Tapatalk Link to comment Share on other sites More sharing options...
keepclam Posted February 3, 2022 Share Posted February 3, 2022 Any difference in the 5EAT from 2006 to 2007? Is it plug-and-play, or close? I heard the valve body was improved, but can't find documentation other than the part number being different. My 2006 has failed and I'm considering a remanufactured transmission. (Also open to thoughts on reman vs rebuild, with primary consideration being reliability/longevity.) Link to comment Share on other sites More sharing options...
m sprank Posted February 9, 2022 Share Posted February 9, 2022 Valve body changed in 08. Improved, it was not, but call it what you want. 05-07 are the same. Link to comment Share on other sites More sharing options...
whitexc Posted February 9, 2022 Share Posted February 9, 2022 I dislike the 5EAT in my 2009. I wish I was rowing gears, be it 5 or 6. Can't at this point justify a swap though so continuing with the auto that shifts how it wants when it wants it shall be. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
ohno06gt Posted February 12, 2022 Share Posted February 12, 2022 Does anyone know the proper relearning procedure for 5eat? I cleared memory 2 with a vag com using freessm. I recall someone saying to shift through the gears in manual mode at around 12% throttle but at what rpm? Also how long should it take to relearn? Car shifts fine when under a decent load but low load it's still clunking into gears. Link to comment Share on other sites More sharing options...
whitexc Posted February 12, 2022 Share Posted February 12, 2022 Go here....https://prnt.sc/12q47lm It is a screenshot of the FSM relearn procedure. Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
keepclam Posted February 12, 2022 Share Posted February 12, 2022 Any difference in the 5EAT from 2006 to 2007? Is it plug-and-play, or close? I heard the valve body was improved, but can't find documentation other than the part number being different. My 2006 has failed and I'm considering a remanufactured transmission. (Also open to thoughts on reman vs rebuild, with primary consideration being reliability/longevity.) For posterity’s sake… here’s what a local Subie shop told me, and another Subie shop confirmed the same: “While the chassis' are similar from 06 and 07, the CANBUS system is almost entirely different, meaning swapping of equipment from 06 to 07, is nearly impossible to do correctly. Putting an 07 into your 06, along with SI drive would require changing the vehicle harness as well.” So, going with an 06 Subaru reman 5EAT (and am told this is the last unit currently in stock in the country). Link to comment Share on other sites More sharing options...
m sprank Posted February 14, 2022 Share Posted February 14, 2022 You sir were misinformed. 05-07 is the same. 08-09 is the same. The change came with the 08 model year. I have personally owned an 05 LGT 5EAT, 05 LGT Limited 5EAT and 08 LGT Limited 5EAT. Link to comment Share on other sites More sharing options...
kzr750r1 Posted February 14, 2022 Share Posted February 14, 2022 Thanks for piping in here sir! Was just thinking it is a shame You and David are no longer directly involved in helping us keeping these cars together. Link to comment Share on other sites More sharing options...
ohno06gt Posted February 17, 2022 Share Posted February 17, 2022 Go here....https://prnt.sc/12q47lm It is a screenshot of the FSM relearn procedure. Sent from my SM-G996U using Tapatalk No access to a lift and I'm using free ssm which doesn't walk through the steps as far as I can tell. Could have sworn I saw a different relearn procedure but can't seem to find it now. Link to comment Share on other sites More sharing options...
whitexc Posted February 17, 2022 Share Posted February 17, 2022 (edited) I have done a reset a few times to my 5EAT. I have just gotten in and driven normally for a bit. Not sure it's right or wrong and sometimes it lasts months, other times not as long. I believe I may be suffering from turbine speed sensor 2 failure (seems to be heat related) after a fair amount of reading here and elsewhere. I may upgrade the VB and swap the sensor out at the same time. Still getting the new shortock wound to stop bleeding. Sent from my SM-G996U using Tapatalk Edited February 18, 2022 by whitexc Link to comment Share on other sites More sharing options...
Rpmiller6601 Posted March 3, 2022 Share Posted March 3, 2022 I have been reading through posts here for a couple of years and can always find the answer to my problem with the plethora of information provided here. So thank you for that. Now I've come to a dead end with my car, and can't find anything that matches up quite the same. I'd like to make a new post but I'm a little lost on how to go about that. The issue is huge, horribly loud rattle, clacking noise while accelerating up to 25 mph, after that it runs perfectly fine. Aside from a small ticks once in awhile that I can't repeat. Same sound when on all 4 Jack's. Everything I've found here and on YouTube it looks like the center diff. I pulled out the planetary gear set, and was hoping to find ball bearings loose, teeth shredded, something. But it all looks perfectly fine. There is a clicking noise while I spin it with my hand tho. I can't quite figure out the best way to go about this now. If anyone can point me in the right direction I'd greatly appreciate it. 06 Subaru legacy GT 2.5 5eat Thanks in advance. Link to comment Share on other sites More sharing options...
whitexc Posted March 3, 2022 Share Posted March 3, 2022 Half shaft/axle in the front? Have they ever been changed? Mileage? Driveshaft/carrier bearing? Sent from my SM-G996U using Tapatalk Link to comment Share on other sites More sharing options...
Rpmiller6601 Posted March 3, 2022 Share Posted March 3, 2022 Half shaft/axle in the front? Have they ever been changed? Mileage? Driveshaft/carrier bearing? Sent from my SM-G996U using Tapatalk 170k miles. Cv axles in the front. Just changed the front passenger side. Everything underneath looks perfectly fine. And drive fine except for the wild noise. With all 4 Jack's, the front passenger wheel does not spin. Turning left, turning right, low speed, high speed, it doesn't spin more than 1 revolution per hour. Changed the passanger axle, and still the same thing. Link to comment Share on other sites More sharing options...
m sprank Posted March 7, 2022 Share Posted March 7, 2022 Front diff. Link to comment Share on other sites More sharing options...
ohno06gt Posted March 16, 2022 Share Posted March 16, 2022 Pretty sure the front diff went out in my 06. Started with a clunking noise while cruising. Initially thought inner cv joint. Now there is a nasty grinding noise with foot on the brake at a stop. Sound like front diff to you guys? Will a 5eat from an 05 be compatible with the 06? Link to comment Share on other sites More sharing options...
m sprank Posted March 17, 2022 Share Posted March 17, 2022 05/06 are the same. Link to comment Share on other sites More sharing options...
lgtPR Posted March 17, 2022 Share Posted March 17, 2022 I have a 05 limited. Started with intermittent issues were the car shifted to a higher gear instead of 2. Also when this happend you can hear a loud clank noise from the back of the car. sometimes i just turned the car off and it drived for a couple of days. Now it makes when you try to drive, i did added like 2 quarts of mobil 1 ATF oil since i changed the radiator lost a little fluid. Not sure if that has to do something. Any inputs of how to sort things out? No local mechanic wants to check my car. I do have mechanic knowledge but limited time. Link to comment Share on other sites More sharing options...
kzr750r1 Posted March 18, 2022 Share Posted March 18, 2022 Do more ATF changes with the factory spec fluid. You were running low so hopefully not hurting internals much. But sounds like your already there... Sorry. Takes about 4.5 quarts each pan drop. More if you tip the car up on the passenger side while draining. Measure and refill... Then check per manual instructions. Fluid changes every other engine oil change is the best way to keep the system clean and running proper. 247K on mine no rebuild. Good luck. Link to comment Share on other sites More sharing options...
samwe Posted November 8, 2022 Share Posted November 8, 2022 I have an '05 3.0r Outback and I think my 5EAT is dead. It slips and shudders really bad in first and second gear. if I switch to manual mode third gear is fine. I started reading this thread looking for sone info, but this is crazy long! What I really want know is what years and models can I get a trans from? Is it true that '05 and '06 are the only interchangeable years? What about an '06 Tribeca? If I can't find a low mileage trans that will work I will start looking for a good shop to rebuild mine, along with discovering all the mods that should be done. Thanks. Link to comment Share on other sites More sharing options...
08LGT5EAT Posted December 2, 2022 Share Posted December 2, 2022 Signed up to add my recent experience in case it helps anyone. I have an 08 GT Limited 5EAT with about 115k miles. A bit more than a year ago, after I pulled out of the driveway and shifted into drive, the car made a completely unexpected and violent series of upshifts. It felt like someone had dumped the clutch or I had driven over a brutal pothole. I was worried about permanent transmission damage. This started a process of intermittent issues that always disappeared when the car was anywhere near a mechanic. I took it to six (!) different places -- including two Subaru dealerships, two transmission specialists, and an auto electrician. One Subaru dealership said the transmission fluid was varnished and overfilled; the last part was strange because I hadn't serviced it since 60k miles and the car tends to leak fluid, not gain it. The other dealership kept the car for two weeks and said they experienced the problem once. But they didn't know what caused it and (nonsensically) wanted to replace the mass airflow sensor. A couple of places picked up some random error codes, but the car's electrical has always been buggy and the shifting issue never seemed to coincide with warning lights. Cut to a few weeks ago, when the problem was becoming much more frequent. On a short drive (the only kind I trusted the car to make), I smelled an unfamiliar burning. My dash turned full Christmas-tree mode and I noticed a new light: AT oil temp. I limped the short distance home and had the car towed to a transmission shop confident that the transmission problem would finally be sorted. The first word I got from the shop was that my radiator was cracked and coolant was "just pouring out." Fine. Not what I cared about, but cars need radiators, so I told them to fix it. After that fix, the mechanic once again said he didn't notice a problem. He kept the car two weeks, driving back and forth trying to figure it out to no avail. When I took it back I fully expected the eventual relapse. But (knock on wood) it's driving as engineered again. What gives? I can't say for sure and I may live to regret posting this as if it's solved. But I found a youtube video that's super intriguing. The video discusses a linkage between a bad radiator and harsh shifting. It specifically discusses upscale Volvos from 1993 to 2000, which obviously isn't a match. But everything else is a perfect description of my experience. In short: In some cars, the radiator cools the engine and the transmission. The Legacy is one of those cars. Sometimes, radiators will fail and leak internally before any external signs of damage appear Because the coolant and the transmission fluid circulate at different pressures, a failing radiator can force fluid into the wrong system The problem usually develops gradually The signs that a radiator is forcing coolant into the transmission are harsh shifts and transmission fluid that is overfilled and discolored The problem itself is very hard to detect until the radiator starts failing externally, and the main symptoms manifest misleadingly in a separate system. But when I saw how many similarities the video had with my own car, I took it back to the transmission shop and had them flush the AT oil. Hopefully, after 14 months of purgatory, the car can settle back into normal life again. I'd have loved to have this information a while ago, so I thought I'd offer it up in case anyone finds it useful. Link to comment Share on other sites More sharing options...
kzr750r1 Posted January 3, 2023 Share Posted January 3, 2023 Well at 257K on my 5EAT it's time to pull it and pay the piper. Currently lockup is slipping and result is terrible fuel mileage. Putting it in Manual helps a little. Not a cure. Looking for transmission lift I can rent and have a friend with car lift available. So at least looks like I don't have to pull the motor to get it out. Last fluid drop did show some clutch pack debris. Did add some Lucas slip fix again as David suggested many years ago. Has not cured it so for sure time to do something more drastic, like get it fixed. I'd like to get at least 28 MPG again on freeway runs. Currently best average is 20. Link to comment Share on other sites More sharing options...
