got some new stuff for engine R&R
Sorry....need to get it out first.
I'll post them later.
Been working on it for about 4 hours so far. The block has broke loose from the tranny on it own.
Engine Build - Click Here
Omg how i wish that was the case w mine! Im still having nightmares from my clutch install! http://legacygt.com/forums/attachment.php?attachmentid=57766&d=1222276408
That would be a 1st:rolleyes::lol:. The two time I drop my tranny. I had to use a hammer & chisel to start the separation:mad:.
Mike
Mileage:331487 Retired/Sold
it's all good. I was just teasing you.
Yes, I knew that...here's some photo's.
The vf52 has over 11,000 miles and has zero shaft play.
I was pleased that there was no oil in the spark plug holes.
I also had to buy a O2 sensor socket and set of metric hex bits so I can pull the pressure plate. We did that while we were waiting for our diner reservations. Sears hardware was in the plaza with the 99. Had to go the Auto Zone for the socket.
I spent about 8 hours to get the engine to where it is now. I'll finish taking it apart tomorrow.
Edited by Max Capacity
Good stuff. Are you doing all the work yourself?
Yes all by myself, that way I can learn what not to do the first time...lol My GF helped me guide it out of the car and labeled some ziplock bags for me.
Were you having a small oil leak from the passenger side rocker cover? Lower bolts appear wet (5th picture).
Yes very small leak, very intermittent. I believe the front bolt was not as tight as the rest of them.
I'll post more pictures in a few, shower time now.
Oh its in the back of the 86 ford F150 ready to go to the machine shop.
Here's more photo's that I needed to re-post.
Here's more, and why the dip stick is so hard to read, notice the angle that it goes in the pan.
NOTE Looks it might be just easier to post all the photos in a new post at the end of this thread.added the photos Sept 23 2019
You are, literally, the only person I know who has had good luck with Spec clutches.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
I'm begining to think that...too. This 2+ was getting close to the end of its life. But served me well.
OH btw, I took about 65 pictures but figured you didn't need to see all of them. ;)
^Who says so? I want to see :).
I'll post a few more here, the heads are getting some porting and polishing, so I'll post more picture after they are done.
Good work!
I see that fumoto valve is awfully corroded :lol:
I was noticing that too, the one on the Spec doesn't look that bad.
http://i185.photobucket.com/albums/x40/92Si/DSCN4711.jpg
Had fun with the heat shields
http://i185.photobucket.com/albums/x40/92Si/DSCN4729.jpg
Will be getting a new crossover pipe
http://i185.photobucket.com/albums/x40/92Si/DSCN4727.jpg
Also will pick up new coolant hoses too.
Just received the TSK3 Replacement TOB from AZPinstalls.com the new oil pump should be here tomorrow.
I stopped by the machine shop today and picked up the oem rotors for the Spec. I'll get a picture of the surface grinding they do.
http://i185.photobucket.com/albums/x40/92Si/DSCN4747.jpg
http://i185.photobucket.com/albums/x40/92Si/DSCN4745.jpg
Oh yea, I cut some of the pesky rusted bolts of the heat shields and just got any old nut bolt and washers with anti-seize compound to take there place.
I know I know you want to see pictures...I'll take them next I play with the stuff.
Sometime during the week I'll put new orange o-rings in the intake manifold to TGV's.
I have also tighten up all the pesky gas line clamps, most of them I got 3 turns on the screws. That should stop the gas smell when cold.
Got the oil pump from AZPinstalls today.
Yesterday I stopped by the dealership and ordered new coolant hoses. Just about all of them...
