TRSCobra Posted September 4, 2012 Share Posted September 4, 2012 UP/DP/intake/Tune/bigger F/TMIC or any combination of that as long as it includes up/dp is a good definition of stg2? That, or just have a catch-all "stock turbo" category. Link to comment Share on other sites More sharing options...
timbo7 Posted September 4, 2012 Share Posted September 4, 2012 yea you should be able to trap much higher than 99mph. at least a 102 with the mentioned mods. even more with an infamous tune. i just went stage 2 last week with a dp and an accessport tune. shooting for a 13.5 or better. i'll post it up by saturday i had about 6 runs and i couldnt even hit 99. i doubt id be able to get 102. post up your results when you go. Link to comment Share on other sites More sharing options...
Brett Posted September 4, 2012 Share Posted September 4, 2012 i had about 6 runs and i couldnt even hit 99. i doubt id be able to get 102. post up your results when you go. are you at high elevation? im like 40ft above sea level. higher elevation makes you slower. i'll post it by saturday Link to comment Share on other sites More sharing options...
timbo7 Posted September 5, 2012 Share Posted September 5, 2012 are you at high elevation? im like 40ft above sea level. higher elevation makes you slower. i'll post it by saturday Its like 500ft where i was. what mods do you have done? Link to comment Share on other sites More sharing options...
BENCOB Posted September 5, 2012 Share Posted September 5, 2012 http://i765.photobucket.com/albums/xx295/AILEBABER/tourdecorse1993subaruledk0.jpg?t=1346843631 Link to comment Share on other sites More sharing options...
BDII Posted September 5, 2012 Author Share Posted September 5, 2012 That, or just have a catch-all "stock turbo" category. excellent idea Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Brett Posted September 5, 2012 Share Posted September 5, 2012 Its like 500ft where i was. what mods do you have done? just an invidia catless downpipe with the stg2 cobb AP map. i'm running almost 3psi higher than before with stg1. i can't wait Link to comment Share on other sites More sharing options...
BDII Posted September 6, 2012 Author Share Posted September 6, 2012 There are a lot of factors that determine how fast you will run. You can't compare your times, apples to apples, with other cars and drivers. There are people on forum that could run a stock legacy at stg2 numbers. The best you can do is work on your individual technique. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
dr_sharp Posted September 6, 2012 Share Posted September 6, 2012 There are a lot of factors that determine how fast you will run. You can't compare your times, apples to apples, with other cars and drivers. There are people on forum that could run a stock legacy at stg2 numbers. The best you can do is work on your individual technique. So true.. and to add to that, environmental conditions like temperature, humidity, elevation, and track condition can make or break a good time. lol Link to comment Share on other sites More sharing options...
BDII Posted September 6, 2012 Author Share Posted September 6, 2012 The best drag runners I know are constantly checking tire temps/conditions/pressure, engine temps, oil wear, fluid temps, diff temps, trans temps, track temps, pit temps, barometric pressure, humidity, fuel atomization... the list is endless. The best advice I can give is ask the people who know the track questions, a lot of questions. like which lane runs the fastest, which pits are the stickiest, what the weather is etc etc.. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Brett Posted September 7, 2012 Share Posted September 7, 2012 so far, run #1 is: 13.652 @100.64 i did a second run and winded up with a 13.9 @99.75 need to let it coold down for a bit. oh, and i had to wear a helmet for my second, so my awareness was a little off Link to comment Share on other sites More sharing options...
BDII Posted September 8, 2012 Author Share Posted September 8, 2012 5lbs bag of ice on the intercooler. Track local to me sells them for $3.00 Lay it down easy or your get some bent fins. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
timbo7 Posted September 8, 2012 Share Posted September 8, 2012 so far, run #1 is: 13.652 @100.64 i did a second run and winded up with a 13.9 @99.75 need to let it coold down for a bit. oh, and i had to wear a helmet for my second, so my awareness was a little off nice run, I wonder why my mph was so low. Maybe im a slow shifter....idk What kind of 60ft are you getting? Link to comment Share on other sites More sharing options...
Brett Posted September 8, 2012 Share Posted September 8, 2012 nice run, I wonder why my mph was so low. Maybe im a slow shifter....idk What kind of 60ft are you getting? i had a best 60ft of 1.919. then i had two 2.0's. i can't get my launch down. that's the best i've had yet. based off these times, the launch makes a big difference in the end. and shifts make a huge difference too. Link to comment Share on other sites More sharing options...
Brett Posted September 8, 2012 Share Posted September 8, 2012 5lbs bag of ice on the intercooler. Track local to me sells them for $3.00 Lay it down easy or your get some bent fins. aww, too late lol. i left at 8:40 Link to comment Share on other sites More sharing options...
07spec_b Posted September 22, 2012 Share Posted September 22, 2012 http://imageshack.us/a/img838/5979/p9050531.jpg St. Thomas dragway Date: 21/09/2012 Ambient Temp: 60 Elevation: 600ft Weather: clear Car: 2007 subaru legacy spec b Tuner: innovative Transmission: 6speed Peak Horse Power at RPM: 400 Peak Torque at RPM: 400 Fuel: 94 50/50 water meth Engine/Power Modifications: avo500, avo fmic, id1000 Driveline Modifications: act hdss Suspension Modifications: avo rear sway, swift springs Link to comment Share on other sites More sharing options...
BDII Posted September 23, 2012 Author Share Posted September 23, 2012 please clarify which one you are. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Brett Posted September 23, 2012 Share Posted September 23, 2012 i'm guessing the one on the left Link to comment Share on other sites More sharing options...
07spec_b Posted September 23, 2012 Share Posted September 23, 2012 i am 13 Link to comment Share on other sites More sharing options...
dr_sharp Posted September 23, 2012 Share Posted September 23, 2012 nice run lol Link to comment Share on other sites More sharing options...
Brett Posted September 24, 2012 Share Posted September 24, 2012 oh damn! nice run. sorry for under estimating your time. Link to comment Share on other sites More sharing options...
Turkeylord Posted September 24, 2012 Share Posted September 24, 2012 Event: Tintmasters Street Legal Drags Location: Top End Dragways, Sabin, MN Date: 09/23/2012 Ambient Temp: 60°F Elevation: 928 ft Weather: Clear, 30.18 inHg, 25% Rel. Humidity Car: 2005 Subaru Legacy GT Wagon Tuner: Ron Soliman, RS Motors in Burnsville, MN Transmission: 5MT Fuel: E85 Engine/Power Modifications: BNR Evo3 16g, AVO TMIC, Invidia UP, Cobb catted DP, DW 850 sidefeeds, DW 65c fuel pump, GS EBCS, Cobb APv2 Driveline Modifications: None, Stock clutch Suspension Modifications: Whiteline 22mm RSB Other Modifications: Removed spare, jack & trays, & floor mats. http://i140.photobucket.com/albums/r16/turkeylord/2005%20Legacy%20GT/3641_001_zpsf0dfbe4d.jpg http://imgur.com/0V0WU.jpg Link to comment Share on other sites More sharing options...
lee07 Posted September 24, 2012 Share Posted September 24, 2012 Turkeylord, What did it put down at RS? Sure you could of gotten a 12.9 or so out of it Link to comment Share on other sites More sharing options...
dr_sharp Posted September 24, 2012 Share Posted September 24, 2012 the trap speed seems low for that turbo on E85. lol Link to comment Share on other sites More sharing options...
Turkeylord Posted September 24, 2012 Share Posted September 24, 2012 Turkeylord, What did it put down at RS? Sure you could of gotten a 12.9 or so out of itWe didn't get it finished while I was down there - he had missed an alternate wastegate table in the tune. So unfortunately, no number My best 'segments' of the day add up to 13.05, but a 12.9x might be doable... Link to comment Share on other sites More sharing options...
