BDII Posted April 16, 2012 Share Posted April 16, 2012 (edited) Thread Title: Dyno Tune: Shop/Tuner, WHP/WTRQ, TURBO, Motor displacement (2.0/2.5), PSI example: Dyno Tune: EFI Logics makes 298whp on a 2.5L + 68HTA @ 20.8psi Event: Dyno Pull/road run/track run Loaction: name of the Shop or Track Date: 08/11/2010 Ambient Temp: in F Elevation: Google can help you with this Weather: Rain? Snow? clear? Car: year, make and model Tuner: Name of person and shop Dyno Info: Mustang, dynometer, airboy, ect ect Transmission: 5speed, 6speed, PPG, JDM, ect ect Gear: What gear the pull was done in (2nd,3rd,4th,5th) Peak Horse Power at RPM: The RPM that you reached max HP Peak Torque at RPM: The RPM you reached Max TQ Baseline hp/tq for a stock on same dyno: your model with no mods Target Boost: In PSI Target AFR: SAE Correction factor: Fuel: Octane rating if pump, octane and brand if specialty fuel Engine/Power Modifications: Anything that adds horsepower that you have added to your car. i.e. bigger turbo, intercooler, exhaust, injectors Driveline Modifications: Stock/Upgraded clutch, light weight flywheel, upgraded drive shaft, upgraded rear or center diff. Suspension Modifications: struts, springs, coilovers, braces, bushings, and other items that reduce body motion and increase power transfer to the ground Other Modifications: weight removal, addition of a roll cage, lighter wheels or rotors, smaller than OE diameter tires, and other items that affect vehicle weight, rotational inertia, and power delivered to the contact patch Picture of Dyno Plot and AFR/Boost Plot: Ask your tuner for this or copy it from your tuning software Edited April 16, 2012 by BDII Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
SSpeed Posted April 16, 2012 Share Posted April 16, 2012 Can we add correction factor in to this? Link to comment Share on other sites More sharing options...
BDII Posted April 16, 2012 Author Share Posted April 16, 2012 forgot, thanks for the heads up. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted April 17, 2012 Mega Users Share Posted April 17, 2012 nice work, now get it stickied! "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
BDII Posted April 17, 2012 Author Share Posted April 17, 2012 that's the Hope Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
StoplightAssassin Posted June 29, 2012 Share Posted June 29, 2012 Another suggestion "Dyno chart" by itself is not a good thread title. We expect to see a dyno chart or timeslip in this forum. Put some more specific info in it relevant to your thread such as "Dyno: 05 GT 5MT Stg 2 PDX e-tuned" or "Dyno: AVO 450 300whp 5EAT" Link to comment Share on other sites More sharing options...
BDII Posted June 29, 2012 Author Share Posted June 29, 2012 Thread Title: Dyno Tune: Shop/Tuner, WHP/WTRQ, TURBO, Motor displacement (2.0/2.5), PSI Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
StoplightAssassin Posted June 29, 2012 Share Posted June 29, 2012 tl;dr Link to comment Share on other sites More sharing options...
Thinking out side box Posted March 31, 2016 Share Posted March 31, 2016 1st graph-original setup 2nd graph- additional mods 3rd graph- additional mods and fresh oem block. Just got back from my tune at Topspeed. Thankfully i have taken all of my past subaru's there to be tuned, so i can do come head to head dyno comparison. -My set up 05 LGT w/100k miles Bnr 18g/perrin tmic/grimmspeed ebcs stock intake with k&n Full exhaust with high flow catted down pipe Dw 65c fuel pump and 850cc injectors -The numbers A little disappointed in the numbers, i was expecting ~320whp and ~350wtq on this dyno. http://legacygt.com/forums/images/statusicon/wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1024x565.http://i306.photobucket.com/albums/nn263/mcgowsd/7ed9261f.jpg Here you see my 21psi pump gas map and 17psi DD map. Besides the tq just being a bit shy of my expectations, it took longer in my lgt to reach peak tq then in my similar hp wrx and sti, the turbo would be fully spooled, but wouldnt hit peak tq until another 500-750 rpms later(maybe this is a lgt intake manifold thing). On the hp front, the maf was locked @ 4.6v's for about 1k rpms in the upper power band(right where the car holds 300whp), we have a good suspicion that we reached a flow bottle neck at this point limiting me to ~300whp, perhaps the oem inlet? Overall the car is much faster however, i suspect it has gone from a ~102mph stage 2 car to a ~108mph car. Much more power up high, the car no longer has a tq spike and falls on its face higher in the rev range. Anyways, here is a neat comparo for you to digest. My 05 sti and 02 WRX with stock motors and vf-39 on pump gas vs my 18 LGT on pump gas. 21psi for all cars. Enjoy! http://legacygt.com/forums/images/statusicon/wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1024x565.http://i306.photobucket.com/albums/nn263/mcgowsd/0e56b57b.jpg Edit: RETUNED 12/23/12 after going catless w/AEM intake Went catless and added an intake/retuned 310/340. Ill take it. Planning on a exhaust manifold and inlet next year.http://legacygt.com/forums/images/statusicon/wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1024x768.http://i306.photobucket.com/albums/nn263/mcgowsd/B3765BC6-4746-411D-99F2-32104A881447-311-0000002CB371DDB0.jpg Retuned 3/3/14. -Added Fast motorsport TMIC -Perrin up pipe -New oem block to replace cracked ringland -Graphs you see are 18 psi safe pump map, 21 psi pump map, 21 psi 97 octane "race gas" map. She drives great. http://legacygt.com/forums/images/statusicon/wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1024x558.http://i306.photobucket.com/albums/nn263/mcgowsd/8F9A6C16-7481-471D-B50B-57751F539686_zpskaknwnvt.jpg Link to comment Share on other sites More sharing options...
