lisa Posted June 28, 2005 Share Posted June 28, 2005 Can anyone please tell me how the hell you turn off that annoying beep, beep sound from the seatbelt when you're not wearing it??? I had a large gym bag in my front seat, obviously weighing over the 25lb limit and the damn seatbelt dinging started going off. I had to pull-over and put the bag in the back seat. Link to comment Share on other sites More sharing options...
wukindada Posted June 28, 2005 Share Posted June 28, 2005 Insert the belt into the latch 13-15 times it will stop;) (I know it's a pain) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
rallispec Posted June 28, 2005 Share Posted June 28, 2005 http://legacygt.com/forums/showthread.php?t=6210&highlight=seatbelt+chime Link to comment Share on other sites More sharing options...
Kaptan Posted June 28, 2005 Share Posted June 28, 2005 ^ That is not correct, just do a search and you will find your answer. There are already more than a few threads on the subject. Link to comment Share on other sites More sharing options...
rallispec Posted June 28, 2005 Share Posted June 28, 2005 Ok... I read through the other thread like 30 times repeatedly tried what it said... 1. turn key to acc on 2. plug in seat belt (all the way till it clicks)/unplug seatbelt 20 times Rapidly 3. turn off key 4. Repeat 1-3 5. Start car... By "plug in seat belt" I mean all the way so the light goes out and it clicks... By "unplug seat belt" I mean push the release button and let the belt anchor pop out of the reciever. Well, I noticed (after repeated tries the way it says) that the seat belt light went out after the initial bells/blinks after doing the sequence JUST ONCE... Well... I spent some time playing with it last night and WITHOUT A DOUBT on my 05 Legacy 2.5i Wagon that if you do the full sequence 2 times like suggested it deactivates the bells the first time and reactivates them the second... SO JUST FOR CLARIFICATION... ON MY CAR WITH NO DOUBT WHAT SO EVER. To dis-able the Seatbelt Chime... 1. turn key on to acc position (do not start car). 2. buckle and un-buckle the seatbelt 20 times (or more (could be less I didn't bother trying lower numbers... I will though.)) 3. turn the key to the off position. 4. start the car... You do NOT need to wait for the initial chimes to finish for ANY of the steps. ALSO  KEEP IN MIND that this COMPLETELY ELIMINATES BOTH THE CHIME/BELL AND the CLUSTER REMINDER LIGHT. After the initial bells/chimes and blinks of the reminder light, the light goes OUT and the bells do not chime again...  As far as the cold temperature reset... I don't know about that... it hasn't been that cold here since I disabled it. . Link to comment Share on other sites More sharing options...
melayout Posted June 28, 2005 Share Posted June 28, 2005 Just about to post teh same link. wukindada - I bet lisa would've beat you up after trying to no avail, with those vague instructions. I keed I keeed Link to comment Share on other sites More sharing options...
lisa Posted June 28, 2005 Author Share Posted June 28, 2005 Are you kidding me?? Is this the new Chinese Car Drill of seatbelts?? With all the gagets and gizmo's this car has you mean to tell me I have to do all that?? This is not rocket science! I'll suffer with the ding, ding, beep, beep but thank you for your input anyway. Link to comment Share on other sites More sharing options...
c-lo Posted June 28, 2005 Share Posted June 28, 2005 Are you kidding me?? Is this the new Chinese Car Drill of seatbelts?? With all the gagets and gizmo's this car has you mean to tell me I have to do all that?? This is not rocket science! I'll suffer with the ding, ding, beep, beep but thank you for your input anyway. Wow, it's really not that hard. Just follow steps 1-4 from the above thread. It's pretty easy and takes less than a minute 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
fbi012 Posted June 28, 2005 Share Posted June 28, 2005 lol, the whole thing takes 5 seconds... The instructions r extra clear so everyone can understand them, you might let it go now but eventually u'll come back and disable the annoying beep. Link to comment Share on other sites More sharing options...
lisa Posted June 28, 2005 Author Share Posted June 28, 2005 I didn't say it was hard just monotonous and stupid. Thank you for you help, though. I will try it out for the sake of it and a good laugh. Link to comment Share on other sites More sharing options...
RockyMtnGT Posted July 11, 2005 Share Posted July 11, 2005 Did it last nite...took less than 5 minutes. And it worked great THANK YOU! Link to comment Share on other sites More sharing options...
Brady Posted July 11, 2005 Share Posted July 11, 2005 It's not like you have to do this over and over! I did it a couple days after buying the car. The idea of it going off if I pulled up to an ATM or unbuckled at a drive through was enough to make me nuts without even experiencing it. Link to comment Share on other sites More sharing options...
