ecw Posted January 10, 2012 Share Posted January 10, 2012 Is a 5mt from a 2007 LGT a direct replacement in 2005 LGT? Everywhere I look shows 05-06 being the same but cant find info on 07+. Link to comment Share on other sites More sharing options...
whitetiger Posted January 10, 2012 Share Posted January 10, 2012 yes and no. the final drive ratio is different. if you do want to use the 07+ mt, you should take it with a matching rear diff so the drive ratio is the same. 05-06 final drive is 4.11 and 07+ is 3.90 i believe. Link to comment Share on other sites More sharing options...
ecw Posted January 10, 2012 Author Share Posted January 10, 2012 yes and no. the final drive ratio is different. if you do want to use the 07+ mt, you should take it with a matching rear diff so the drive ratio is the same. 05-06 final drive is 4.11 and 07+ is 3.90 i believe. Thank you for the info! Link to comment Share on other sites More sharing options...
